Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 43 Guests are viewing this topic.
profitis
Sadang:'Or buy a ferrocell'
Does this 'ferrocell' contain Fe2O3 particles inside of it
profitis
Apophasis:'with biological experiments that are 100% reproducible by anyone.'
Cannot and will not RULE OUT MHD-lenz
sm0ky2
@Sadang
if you can get through the senseless ranting, psychobabble, and general degradation of intelligences beyond his own, and get down to the core data of his theories.....
You will find that he makes use of Phi, very much like Euler did, without respect to the imaginary (j) side of the equations.
This is evident in his understanding of the dielectric/diamagnetic properties.
This was corrected by implementation of the Mobius function (inversion), and gives a much clearer example.
You will find that both the dielectric and diamagnetic are equal and opposite to their electric and magnetic counterparts.
His magnetic "experiments" are used to describe a motion, using relatively stationary objects...
As per his description of the shape of the field, spherical and elliptical
this is just as easily described as a relativistic spatial distortion as a function of Pi (spherical), or a function of e (elliptical) respectively.
What exactly is the velocity of a stationary object? Where is the motion, after it reaches equilibrium within the field?
This abstract description is not verified by his work.
sm0ky2
Quote from: profitis on March 19, 2015, 10:46:43 AM
a FerroCell, is essentially a "metamaterial" with a refraction index and polarization effect.
They can isolate specific frequencies of light and polarize it in such a manner that
it becomes susceptible to a magnetic field influence. Which will alter the vector or angle, according to polarity and field intensity.
see:  Transformation Optics
profitis
Smoky2:'I think we would need something like nano-ferrites (or individual atoms) free floating in a vacuum, outside any major gravitational influence.
  Then, we may be able to "test" for a vortex.'
Or we could simply re-do the bismuth test to effectively RULE OUT lenz-interference
