Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 55 Guests are viewing this topic.
sadang
Let's now continue with the second most important modality of ether, namely magnetism, and see how Ken describes it:
- magnetism is Ether in a state of dynamic circular polarization upon itself
- magnetism is radiation, is definitionally the "dielectric field"- Faraday (and Maxwell)
- magnetism is the cause of the acceleration, rather inductive polarization by means of dielectric coherency
- magnetism is a pressure gradient of the Ether
- magnetism is a secondary response to dielectric forces
- magnetism is purely radiative, is the termination of electrification and the end-of-road byproduct of dielectricity
- magnetism is identical in that CW on CW approaches are a counter-voidance inertial plane torque of immense resistance.
- magnetism is only present as an attribute to another which is prior (however both are co-eternal and consubstantial, or 'where there is one you will always find the other')
- magnetism is radiation by definition
- magnetism is the dielectric field – Michael Faraday
- magnetism is the discharge Ether modality of dielectricity in termination.
- magnetism is the radiative discharge of dielectricity, or electrification in discharge at which time it terminates AS magnetism in losing its dielectric component.
- magnetism is spatial
- magnetism is but one force itself, however as magnetism is purely spatial in denotation it is polarized but as one moving Ether 'sink' and 'bubble'; magnetism has but one movement not two, nor 'two poles', CW and CCW are spatial abstractions of a singular movement of the magnetic field itself.
- magnetism is a spatial dimension
- magnetism is a versor solely of space (being circular, but not IN space, rather has an attributional quality OF space since a polarized Ether modality 'contains space' but is not in space).
- magnetism is definitionally polarized, it moves as pressure dictates it must
- magnetism is the 'dielectric field', is dielectricity in discharge, the radiation of same
- magnetism is a resultant of coherent inter-atomic dielectricity aligned to yield resultant polarized magnetic reciprocations
- magnetism is literally the polarized spatial 'breaks' upon which the universe is self-regulating
- magnetism is the spatial 'recoil' of electricity in termination, but is not the conjugate of electricity as conceived predominately as
'electromagnetism'
- magnetism is purely a spatial phenomena (as space) in circulation
- magnetism is almost rather literally a magneto-dielectric gyroscope in which the dilated inter-atomic dielectric 'flywheel' created in electrification is counterbalanced by the centrifugal and centripetal (polarized) Z-axial magnetic aperture, which is the accurate model
of magnetism, up to a point
- magnetism is a spatial circular reciprocating vortex, an Etheric pair of fountains and countersinks
- magnetism is definitionally spatial movement
- magnetism is a versor with (space in the field) space
- magnetism is the basis for the quadrature of the universe
- magnetism is a spatial field
- magnetism is a spatial conjugation, a polarization moving outwards in increasing and decreasing pressure gradients towards the dielectric inertial plane, whereas the centripetal counterspatial dielectric increases towards electro-stable generation and is discharged, or terminated in mass and resultantly gravity.
- magnetism is, of course, merely a polarized Ether bubble from electrification (not 'magnetization' as conventionally understood by the common person) of the iron, or neodymium-iron-boron mass, or in an electromagnet, or as is the case in the inter-atomic magneto-dielectric
volume
- magnetism is merely the model expression of Ether polarization in a spatially reciprocating circular
- magnetism is spatial, circular, centrifugal (and centripetal) and polarized
- magnetism is literally the polarization of dielectricity
- magnetism is strictly an end product of dynamic polarization into static radiative polarization, or as the byproduct of dielectric saturation which expels the resident magnetism in a system
- magnetism is created as a byproduct of dielectric manipulation, either by electrification into a mass which distorts the dielectric (meaning acceleration and capacitance) and likewise in turn the magnetic, or as the necessitated conjugate to electrification in TEM
- magnetism is Ether in preturbative movement
- magnetism is a posterior resultant to a prior which is dielectric coherency
- magnetism is by nature the rotary polarized terminus of electricity, a waste product and necessitated conjugate terminal of charge-discharge terminals of natural electrical inertia and momentum
- magnetism is a hyperbolic torque (tension) by which the Ether modality of inertia in discharge mediates its own discharge in creating the hyperboloid of magnetic centrifugal divergence against the inertial 'line' of the dielectric inertial plane of the so-called "magnet" (the coherent dielectric object) and mediates this pressure by polarized reciprocation and transverse reintegration once inertia has been regained
- magnetism is the necessitated spatial expression of inertial loss of dielectricity, which causes spatial reciprocation as the Ether modality of magnetism after which time it must terminate where dielectric voidance is lowest, centripetally on the other pole.
- magnetism is the radiation, the hyperboloid spatial vectorization and polarization of dielectricity in discharge
- magnetism is a circumferential force
More details for ordinary people in the book called "Uncovering the missing Secret of Magnetism", for studious skeptics in the scientific literature prior relativity, and for dogmatic skeptics there are no more details.
Raz
Some of the things Tesla invented:
1.AC Generator.
2.fluorescent tubes-manufactured and used them 40 years before the industry"invented " them.
3.X-rays.
4.Radio
5.Remote control
6.laser
7.Electric motors
8.robotics
9.Wireless communication
10.Disk rotary turbine-(only turbine that can handle 2 and 3 phases gas/liquid/air without cavitation or self destruction)
11.Superconductivity
12.electrotherapy
+ more than 111 patents and his dynamic theory of gravity which he was going to give freely to the world and it is on a national security vault after the CIA raided his apartment when he died.
Walter Russell predicted more than 2 missing elements before they were discovered years later, and did it with a completely different theory and technology than the established science of his time.
Victor Schrauberger invented a implosion motor/generator, a flying machine, new ways to harnness the power of nature and water and predicted our present day worlwide man made contamination and the death of the forests.
None of them believed in the conventional science of their time. All of them believed in the ether.
So everyone here that says that ether science is not real, dont exist or dont work should go and read a little bit or maybe stop using A/C electricity and all of Tesla's derived inventions until they can prove to Tesla that his machines and the theory he used to develop them did not work.
Now , this guy claims that he made experiments while working at the Sprint corporation that proved that the ether exists and he is giving away his free book full of the experiments , theory, formulas and a way for any engineer to repeat the experiment:
http://www.teslaphysics.com/
Im sure with the data some of the engineers here can duplicate easily the experiment. Have a nice day.
sadang
Thanks Raz for this new book about ether. I like to see many individual researchers gives for free their work and results. That's the real path to real knowledge and for a real evolution of human society.
Quote from: sadang on March 23, 2015, 03:42:56 AM
(insert scrambled random assortment of inconsistent and contradictory word-salad)
That's the most hilarious thing I've read all day. Maybe TA will hire you as an editor! Or maybe he already has!
Raz
You are welcome sadang. The only way any progress will ever be made is when people start giving away freely for the good of the whole instead of trying to capitalize on the gain of the few. The ideal situation right now would be experiments and machinery that the weekend warrior could build on their garage regardless if they understand completely the theory or not but that work to make your life easier and less dependent on the private and government sector. Thanks to everyone who cooperate in this way.
