Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
Quote from: tinman on January 17, 2016, 09:54:22 PM
TK
Why even bother arguing with this clown.
He is all dribble and no action.
Of course he is! I enjoy the clown shows at the circus, don't you? Every time they have a pratfall, we all laugh. When they go walking about in their huge shoes, with that big red rubber ball nose, it's hilarious! And that's what this clown is doing, over and over, with every post he makes.
Just as I predicted earlier, he'll never demonstrate anything that supports his silly claims. He cannot !
(And Kenny won't retract his silly claims either. "Genuine Free Energy" from a bismuth sphere placed next to a magnet! What a hoot!  This is the thread to see who can come up with the silliest, most absurd claims, along with the prettiest silly graphics.)
Quote from: Atommix93rdAtom1 on January 17, 2016, 06:31:23 PM
If I was as thick as you I would float on water hahahaha That tick seems to me ok as long as he keeps taking it out than puts it back in but that will take some energy hahahahaha ...
The thing about the transformer trick is its deadly !!! a few modulators and its frequency goes so high and its amps follow that the end result is lasers everywhere ... You can buy a small green light laser on ebay and its got a 10 mile beam and it can also light a match for just a few bucks ....... That's pounds here in the uk !
So now we have this interesting little monster that costs less than a train ticket to build and can hit an airline and bring it down ! So I don't see the joke in that TinselKoala BUT YOU DO DONT YOU SON !
TinselKoala You need some TLC son and I have just the thing for you .. Its called a 12 000 ft drop and you have to belly flop into a paddle pool .......... It wont hurt you son your so think you just bounce back up to the plane wont you hahahahahahahahahahahaha
Now than so little monster will need some opposition to control it or we are all completely fucked ......
Now you're frothing at the mouth! You should speak to your doctor... you really need to have your medications adjusted, before your brain dissolves and starts running out your earholes!
Try holding your breath, stomping your feet and spinning around in a circle until you fall down! That's so much easier, and more effective, than PROVING YOUR CLAIMS -- which you cannot do, since they are all just figments of your overheated imagination.
CycleGuy
Quote from: TinselKoala on January 17, 2016, 11:53:56 PM
And the funny thing is, even in his insults, he's diametrically opposed to reality. Objects denser than water do not float unless their displacement exceeds their weight... so Mr. Richardson isn't trying to say you're stupid, he's trying to say you're... built like a battleship?  ???
CycleGuy
Here's a good analogy of the QVZPE field and matter:
https://gravityandlevity.wordpress.com/2015/08/20/a-childrens-picture-book-introduction-to-quantum-field-theory/
Essentially, the QVZPE field can be represented in classical form by a bunch of balls on vertical springs, and at the bottom of each ball-and-spring is a ratchet with several latches (each ratchet level representing a certain element of the Periodic Table).
Each ball is connected to its neighboring ball-and-spring with elastic. But in this ball-and-spring universe, the balls have to keep bouncing (ie: the QVZPE field is energetic) and must only bounce up and down by certain amounts (ie: the energy levels are quantized).
So a small wave of energy, which is below that which is required to cause the balls to bounce will produce no propagating waves across the ball-and-spring universe, and given that it's a universe, this means that energy below this threshold is not allowed (ie: there is a minimum energy level to the universe, a ground state).
Mass constitutes a "latched ratchet", where so much energy has been added to these ball-and-springs in a certain region that the ball-and-spring have been compressed and stuck, the ratchet has engaged and that spring remains permanently compressed (making mass permanent) until something trips that ratchet (ie: matter causes a "well" in the QVPZE field, which is what the fabric of space-time is, after all... for elements that are highly "compressed", the ratchet can 'slip', allowing that ball-and-spring to rise slightly (transmutation of heavy elements)).
This 'latched ratchet' ball-and-spring no longer has to keep moving, it has "rest mass". Because that spring has its ratchet engaged, it cannot transmit the bouncing going on throughout the rest of the QVZPE field (ie: matter rejects QVZPE field modes longer than its radius), which tend to keep that spring's ratchet engaged (ie: the fact that matter rejects QVZPE field modes longer than its radius is what gives matter its mass).
But the QVZPE field still acts upon matter (via the elastic, or what we would call the Exchange Interaction), and thus matter is tied to and affected by the QVZPE field, and can affect the QVZPE field.
Now, it stands to reason that matter with less mass would be more affected by the QVZPE field (ie: electrons are so light they are tossed upon the QVZPE field modes so much that we sense them as waves, despite them having rest mass and thereby being matter), whereas heavier atoms are less affected (ie: it takes the highly energetic conditions of an exploding supernova to create mass further down the Periodic Table than iron).
Photons are perturbations upon the QVZPE field that don't cause the spring's ratchets to engage... but mass can be created from photons:
http://www3.imperial.ac.uk/newsandeventspggrp/imperialcollege/newssummary/news_16-5-2014-15-32-44
Breit and Wheeler suggested that it should be possible to turn light into matter by smashing together only two particles of light (photons), to create an electron and a positron – the simplest method of turning light into matter ever predicted. The calculation was found to be theoretically sound but Breit and Wheeler said that they never expected anybody to physically demonstrate their prediction.
And yet again, we see that it entails colliding two energetic photons to cause those spring's ratchets to engage, thereby creating rest mass. The same method by which heavier elements are created in an exploding supernova.
joel321
element93rd, what do you think about this video? https://youtu.be/-4v-xdISLTI
In effect, they say that the humans have an anti-gravity aircraft. And this was filmed by an army pilot, supposedly.
Do you think that OU is possible once and for all? (i do)
What do you think the answer is? (to go live on mars?)
I think it is very clear to me in my mind - those that poses an OU device, or a zero-gravity one, will be rulers of others countries - PERIOD! = politics plain and simple.  ??? GREEED! MONEY! OIL!
We are here talking about stuff that no one has the money nor the balls to do...and how can you when you don't have the monetary nor knowledge support to back you up? lol It has come to my attention that people are just here "debating" to just have a good laugh and NOT really make anything happen. Or can we with your help?  ???
element93rd, 2+2=4.....period. Lets not keep beating the bush. Show us something that can change the wold no matter if people steal your ideas to make money...it is time once and for all. Actions speak louder than words and make the people talking your followers?
