Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 42 Guests are viewing this topic.
profitis
Lol hey joelitis! Let's be everyones friend
except this guy, over there lol!
profitis
"{IMF}(piggyback,piggyback,piggyback)[trump angry
speech] hey joelitis! Let's read this from right to left lol!"
profitis
"I'm not drinking anymore" lol hey joelitis!
Let's create a vampire, over there lol!
isawit
i think ken's magnetism is wrong. he doesn't know how atoms are formed.
MAGNETISM
2 parallel wires at r distance, the free electrons in the 2 wires repel each other with force f=Ke x q1q2/rr, that force is the carrier of energy/moving electric force. if electrons accelerate in wire 1 at 3 volts, electrons in wire 2 will instantly have 3vq1 emf. the true mechanism of electromagnetic induction. same as momentum conservation.
every magnetic atom/magton contains 2 atoms. 2 atoms of a ferromagnetic matter before magnetize, we put it as 00. if 1 electron moved from 1 atom to the other atom and stays there as 01, the 2 atoms become a magton, it carries a special property now, we call it magnetic force.
01, 02, 03...0n are all magton, but carry different magnetic force strength.
2 magtons attract each other in the direction 01+01, and repel each other in the direction 01-10 or 10-01.
use copper wire winding around an iron core, put a current, the electrons in the wire move in circles around the core, make atoms in the core arrange into 0101 directions all the way. on the pole plane area, magtons are arranged as clockwise concentric circles of 0101 directions, north pole.
reverse the current direction, the pole plane area magtons are arranged as counterclockwise concentric circles of 0101 directions, south pole.
so, a magnet north pole stored clockwise electric force, south pole stored the counterclockwise electric force. the same poles always repel, different poles always attract.
the earth magnetic field is a mistake. there is no field but the force in the universe. sunlight moves electrons moving westward causing earth magnetic force interact with compasses.
there is only 1 force exists, coulomb force f=Ke x q1q2/rr. gravity and magnetic force are both different configurations of electric force.
without matters, there is no force. a single matter has no force. force can only exist between matters.
without a test body, where is the electric or magnetic field? where is gravity field?
the mysteries of the universe are within 2 equations.
f=Ke x e1e1/rr and f=G x m1m2/rr.
those 2 forces rule everything existing.
the mechanism of quantum entanglement is simple. the force between any 2 charged particles f=Ke x qp/rr is the carrier of energy/information/moving electric force. it is an invisible physical rod with zero mass that always connected 2 particles as 1. if 1 particle is energized, that energy instantly transferred to another. from f=ma, m=0, so energy instantly moved from 1 particle to another. we call it QE.
Coil Less Ggenerator principle
drop a magnet in a copper tube, it produces current circling the tube, if we cut a gap along the tube, there should be a voltage between the gap.
can we use copper tubing replace the coils to make a generator? it should be less resistance, smaller and lighter.
i wish i can draw or have the euips to try. think this way.
put a magnet on the bike tire, ns pole direction is circling direction, it will generate a current on the fender at 90 degrees, the two edges are the terminals.
Magnetic Propulsion System principle
if we move charged mercury in a ring at high speed, it will produce strong circling electric force/magnetic force/magnetic field. can we use that force interacting with earth magnetic force to produce thrust?
replace the mercury ring by a strong ring magnet, should be the same thing? powered by gas engines?
seen night vision ufo orbs? when they powered up, the orbs increase volume.
seen magnet drop in copper tube producing light?
maybe store the momentum in a flywheel, engage to idle sping magnet whenever need?
maybe use the moving mercury ring as the flywheel, connect it to same mass mercury in an insulated container. make the two bodies of mercury as capacitor terminals.
increase the voltage between the mercury in the ring and the stored mercury, increase the magnetic force. simpler design?
isawit
Quote from: CycleGuy on February 24, 2016, 09:33:51 PM
Did you hear? The LIGO detection of gravity waves was confirmed by a gamma ray signal detection by the Fermi Gamma Ray Satellite 0.04 seconds after LIGO's detection... which is completely what was expected. That must really burn Mr. Wheeler up. LIGO confirmed Einstein's theory, and the FGRS confirmed LIGO.
The two black holes, orbiting close and fast, threw off energy in the form of perturbations in space-time, which caused their orbits to decay... in the final split-second, the energy given off in the form of gravitational waves is estimated to be approximately three times all the mass in our sun. You'll remember my earlier post about how much energy is contained in mass.... 25 terawatt-hours per kilogram... so the amount of energy released boggles the mind.
Eventually, they became so close that the energy given off in the form of gravity waves increased exponentially, exponentially decaying the orbit, giving the "whoop" LIGO detection. The merging of the two black holes momentarily gave energy compressed into those two black holes the opportunity to escape, which it did in the form of extremely high-energy gamma rays, which followed right along behind the gravity waves at the speed of light. This gives a clue as to how long it took for the merger to take place.
The LIGO detection (and the Fermi Gamma Ray Satellite detection) confirms Einstein's theory, but it has important ramifications as regards what we know about the future of the universe, and what the cause of gravity is.
{ANALOGY ALERT}
In the past, I'd used an analogy. There are those who cannot grasp analogies. It'd be best for all concerned if those who struggle to understand analogies didn't read what is written below. That'll save you embarrassing yourself again.  ;D
{/ANALOGY ALERT}
Our universe is somewhat like those coin wells you see, where you roll a coin down a ramp, and it spirals around until it gets to the center, where it drops in. Except the "fabric" of our "coin well" is flexible, and is being continually expanded, expanding the size of the "coin well". And our universe doesn't  have a hole in the center for the "coins" to drop into a coin container.
This happens because our "coin well" universe's "fabric" is the QVZPE field, the fabric of space-time. It can be considered an extension of the stars, a cold plasma, whereas the stars are hot plasma. It is comprised of electromagnetic radiation of all conceivable frequencies.
As stars convert mass to energy via fusion and that energy streams out across the universe, it entropies at a rate of (4/3)*r3 per unit distance due to spreading out spherically. Eventually, it reaches its maximum entropy and thus is considered a part of the QVZPE field. Obviously, this increases QVZPE field radiation pressure. The universe has only two options to relieve this pressure... either concretize mass, or expand. It expands, thus our "coin well" is expanding.
Now, rolling about on this "coin well" fabric of space time are several "coins" of various weights... the planets, moons, stars, black holes, etc... all spiraling slowly (from a cosmological perspective) toward a central point, the universe's "center of gravity", or that point in the universe where all the mass and energy will eventually reach its maximum entropy.
Imagine, if you will, a universe far in the future. All the stars have burned out, thus energy is no longer being pumped out to increase QVZPE field radiation pressure. The black holes have consumed nearly all the matter, and are actively sucking in QVZPE field electromagnetic radiation. Thus, the universe must contract, since QVZPE field radiation pressure is decreasing. The universe is dark, and its fabric is nearly flat (being pulled into those black holes would cause it to flatten out), punctuated by giant wells that are moving about space-time, the black holes trying to reach their highest entropy points.
Now imagine that eventually the universe consists of one gigantic black hole that has engorged itself on all matter and all energy in the universe except one particle far out, a billion light years away from this black hole... the universe's fabric is shaped like a giant ball with a tiny thread extending outward to that single particle. The particle slowly makes its way toward the black hole, accelerating all the while.
Eventually, that particle will merge with the giant black hole, and the universe's space-time fabric will close in on itself, it'll be a giant ball.
Now, we know that gravity is measured by the curvature of space-time, the geodesic deviation from a flat Riemannian space, a tensor known as the Riemann curvature tensor.
Now ask yourself, what happens when the curvature of space-time closes on itself into a ball because the only thing left is that giant black hole? What happens when there is no more QVZPE field because it's been sucked into that massive black hole? The spherical curvature causes gravity to be self-cancelling from all directions, thus gravity does not exist anymore! And at that point in time when the tiny particle finally merges with the black hole, we get another Big Bang because of the tremendous radiation pressure within that black hole no longer being contained by gravity.
ligo is total bs. they detected 2 black holes merged 1.3 billion years ago? how come they cannot detect cme or earthquakes? gravity wave must be instantaneous, otherwise no planets ale to stay in orbit. space-time curvature is bs. einstein is bs.
