Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
isawit
1 electron carries 1 negative charge
if we smash the electron into 1000000 equal pieces, each piece will carry 1/1000000 negative charge. Let's call it enertron.
since enertrons carry the same negative charge, they repel each other.
if we have a perfect bottle, which means no leakage, no react, like glass bottle to air.
we put 1000000 enertrons into the perfect bottle, since enertrons repel each other, they put a pressure on the bottle wall. let's measure and call that pressure 1 volt.
if we put 8000000 enertrons into the same bottle, the pressure on the wall should be 4 volts.
now if 1 enertron is moving or vibrating, the rest all enertrons will be energized.
that is the mechanism of light/quantum.
now if we put 1 positive charge into the perfect bottle, what will happen?
enertrons should be attracted by the positive charge and form a ball around it, the closer to the positive charge the denser enertron cloud. the density of the enertron is decay at 1/rrr due to the repulsion force between enertrons decay at 1/rr.
the enertron cloud is always vibrating, due to the existence of energy, the unbalance attraction force and repulsion force, within the enertron cloud and the center positive charge.
now image enertron is the real thing, it carries a tiny negative charge, something like 1/10^33 electron charge, but it has a stronger force field, similar to neodymium magnet compare with iron magnet.
image proton actually carries 918 positive charges, it attracted 917 total charges of enertrons formed a solid ball, 1 electron attached to the ball to form a neutrally charged hydrogen atom. 1 atomic weight equals to 1936 total charges, no matter positive or negative charges.
this is the realistic atomic structure.
atoms are solid balls, matter is not compressible. such as water.
if atoms are constructed as science told you, why matter is not compressible? electron shell/wave/cloud/orbital are negatively charged, they do not stick to positive changed nuclear is a magic, how can they stand any force/impact/reaction without crashing?
why is energy conserved?
if you push/put a moving force on any enertron with a force f, that force is spreading to all the enertrons in the bottle at light speed, they all are moving now, and cannot stop ever.
do we have a perfect bottle?
yes, every atom is a perfect bottle. all matters are a perfect bottle. energy has nowhere to go but bounce within and between matters.
the forces f=Ke x e1e2/rr and f=G x m1m2/rr are like perfect springs between/within matters, connected all matters in 1.
isawit
profitis
"that is the mechanism of light/quantum."
Alamos like a skin
isawit
Quote from: CycleGuy on February 22, 2016, 01:46:48 AM
Has Mr. Wheeler ever gone to a scientific conference? Perhaps in 2009?
Because a physicist on the Science... Sort Of podcast for 2010/01/24, Episode 20, at time 17:30 (ie: The Science Denialist episode) describes being approached by what he terms a "crank" who described to him his warped take on the definition of "inertia" and "how magnets work"... and Mr. Wheeler is the only one I know of with those attributes.
If so, Mr. Wheeler's hatred of conventional science is entirely understandable... he was rejected by mainstream science because his theory is a crackpot theory... I can't imagine the laughter that would have occurred had the physicist allowed Mr. Wheeler to continue on to babble about there being only one mass particle in the universe that can switch back and forth seemingly randomly between "proton-form" and "neutron-form", all the while denying there are charged particles on both the charge and particle terms, while relying upon a charged particle (the proton) for his odd hobby theory, then describing how his theory says the mass-energy equivalency concept doesn't exist, amongst the sundry other oddities encompassed within Wheelerism... and I'm sure the laughter would rise to howls of hilarity once the hijacked aspects of Dollard Theory, Russellian Theory and Circlon Theory were broached.  :P
you have no clue
mainstream science, from qm to ttb, gr and sr, standard model, maxwell em theory all all BS.
do you want to talk about?
