Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 88 Guests are viewing this topic.
ramset
No Ken
Thats what the back of your eyelids look like...
I know you hardly ever see that ,you should hang it on the wall so you can see what your missin....
4 days with No sleep ..who do you think you are TinMan??
@actually I'm not sure he has slept since you started this thread ...
Later
Chet
Thanks Grandma
mikemongo
Quote from: celsus on July 25, 2014, 07:53:29 PM
Interesting. I tried the same and have the opposite effect.
Are you in the southern hemisphere?
Cap-Z-ro
Quote from: Acca on July 24, 2014, 05:32:13 PM
... I also made ways of making "non-magnetic metals" magnetic.. Sorry can show but not tell !!
Acca..
Acca,
Would your methods be the same, different, of similar to Brian David Anderson's tri-vortex technology ?
Regards...
Tinman:
If PW works with you on your tests you will be in excellent hands, he is the real thing.  I don't have the bandwidth to follow myself.  Nothing has been discovered, it's just a question of explaining the phenomena that you observe.
I made a posting that potentially explained the reason that you did not observe the vortex effect with the solenoid and suggested a test.
All of these observations require that you account for the magnetic field pattern and the current flow pattern.  It's the cross product between these two that determine the direction and the amount of force.  The magnetic field pattern is fairly easy to estimate.  The current flow pattern is less easy, and I have not seen it being discussed seriously.  So my suggestion is when you do a test then you draw diagrams where you map everything out.
The current flow is less easy to visualize and I am willing bet that many can't just by the lack of discussion about it.  The current flows in a curvilinear fashion.  That's something that people should look up otherwise they are just whizzing in the wind.
For the magnetic field viewing film, I probably have looked at 30+ clips over the years and I have never seen anyone use it properly.  In fact, almost all of them just blankly stare at the pattern and say that it "confirms" their assumptions or findings.  It's a great tool but if you don't know how to use it, if you don't make a effort to understand how it works, you don't make a serious attempt to use it and explain to your audience how and why you are doing what you are doing.... then it's no better than an "idiot light" on the dash board of a car.
Take the example of screenshot 1812.   The green line is there and it's showing you that just a tiny part of the magnetic field at the centerline is parallel to the the film.  You know the toroidal pattern of the magnetic field and the polarization of the magnet therefore you know that's where the field is vertical.  The darker blobs above and below are because the magnetic field is crossing through the film and are not parallel to the film.  The brighter parts on either side of the green line are showing you how parts of the toroidal field pattern are also parallel to the plane of the film.  However, they are not necessarily vertical in the outer blobs.  The viewing film does not tell you the exact direction in the plane itself, just that the field is running in the plane of the film.
It looks like the film is bright when the angle of the field relative to the plane of the film is perhaps 15 degrees or less.  Whereas between 15 and 90 degrees the film is dark.  However, knowing the limitations of the film, you can still move it about in various orientations with respect to the magnet and after 10 or 15 minutes you should have enough data to have a pretty decent understanding of what the 3D magnetic field looks like around any magnetic object.
Now, what I wrote above off the top of my head is the most "scholarly" discussion of an image (attached) and how to actually use the film that I have ever seen in any video clip or on any posting on the free energy forums.  Why is that?
Instead, many people place the film on a magnet and see the same line Theoria is talking about and say, "Bloch wall!"  Theoria sees the same line and says "Dielectric Inertial Plane!"   When all that it really is is a small portion of the magnetic field generated by the magnet just off one of square faces is in the same plane as the film itself.  In other words, it's same old toroidal magnetic field pattern we all know.
I will repeat what I said above.  If you want to explain what you are seeing in your clips then do the clip and diagram it out.  Draw how you think the current is flowing through the water then do the cross product with the magnetic field.  If you don't know where the current s flowing then research it.  The do the cross product.  (Note the current flow itself produces a magnetic field.) PW said that you may also have positive ion flow in the water.  Positive ions will curl in an opposite direction to electron flow and perhaps depending on the situation one will predominate over the other.  It may also be related to the amount of current flow.  I don't know, I am just mentioning a possible variable.  (YES it is a significant variable because the magnetic field from the current flow could overwhelm the magnetic field from the magnet or the solenoid.)  I am not 'tasking' you with anything but what I do know is that at typical forum researcher will not go into that level of depth.  Theoria is more typical where he sees something and just jumps onto his own "explanation bandwagon" without making any more tests.  When that happens things quickly degenerate into a farce.
Final thought for you:  Can you come up with a basic form of measurement probe that might help you to map out how the current flows in the water?  It took me all of five seconds to come up with one in my head.
Quote from: Cap-Z-ro on July 25, 2014, 10:18:23 PM
Acca,
Regards...
QuoteAlso, items treated by the harmonic frequencies have been reported to provide soothing comfort, increased energy levels, pain relief (and decrease) swelling in humans and animals. Application and use of products or items treated by the Tri-Vortex® Technology harmonic frequencies are very simple, yet have countless applications. Just place any Tri-Vortex® Technology product against any sized liquid container, or on the area of the body with pain or swelling. The Tri-Vortex® Technology product does not have to be in the liquid for the treatment. (The product will work when the body is clothed, too.)
Can I get away with saying "JACKASS" just once considering all of the Captain Zero thuggery?
