Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 80 Guests are viewing this topic.
tinman
Quote from: gravityblock on July 26, 2014, 04:07:43 AM
TinMan,
Are you sure your cylinder magnet is axially magnetized and not radially?  If I remember correctly you previously stated you couldn't find your compass.  The PM rotating in an opposite direction when the sides are taped is an indicator you are using a radially magnetized cylinder magnet instead of an axially magnetized magnet rotating on it's magnetic axis.  Also, please compare the below quote made by you earlier in the thread with a comment you made in one of your latest videos (snapshot below).  As you can see, in one statement you say the rotation direction doesn't change when flipping the magnet over, and in another statement you say the rotation direction does change when flipping the magnet around.  The apparent contradiction in your statements may also be an indicator of you performing the tests with various magnets having different field configurations.  Also, in one of your videos you referred to a radial magnet as being diametrically magnetized, or vice versa if my memory serves me correctly.  An axially magnetized magnet rotating on it's magnetic axis will rotate in opposite directions when the magnet is flipped over.  However, a radial magnetized magnet will rotate in the same direction when flipped around, and will rotate in opposite directions with the sides taped as compared to no tape.  Can you please verify how your cylinder magnet is magnetized so there is no misunderstanding on my part.
Gravock
Ok-my first quote you have put up,is in regards to my video's-a fixed view point.
The second quote is in regards to a view point associated with one pole of the magnet.If you flip the magnet over,then to obtain the correct field of view to the magnet,then you also must flip your self over 180*. Doing this now show's that the magnet is still spining in the same direction. Just like driving down the road in your car,and looking from the right side of the car,the wheels are spining CW. If we do a U turn,and travel in the opposite direction(180*),and look once again from the right side of the car-the wheels are still spining CW-even we are now traveling in the opposite direction.
All my magnets in the video's!bar one!,are axially magnetized. The video showing the cylinder magnet with the bubbles flowing from one side to the other,is diametrically magnetized.
Cap-Z-ro
Another variable which be of some interest and relavance here:
The stainless steel rod used in Paul Pantone's GEET engine system becomes magnetized during usage.
When held in a vertical position, a compass shows the nort pole on the top and the south at the bottom.
If the rod is flipped end to end, the north pole remains at the top.
It may be worth while to include one of these rods in the experiment.
Also interesting that after being used in the GEET engine, the rod ends up with rings on it, in what appears to be a frequency wave pattern.
Regards...
MarkE
Do you think that there is anything more to Paul Pantone's GEET than cooking off volatiles?
Cap-Z-ro
Quote from: MarkE on July 26, 2014, 08:57:05 AM
There certainly seems to be something unusual involved there...not sure just what tho.
Regards...
MarkE
Of all the accounts that I have read of Pantone and Dennis Lee's copies of Pantone that Dennis pitched when Pantone was locked up in the mental hospital, no one showed measurements that established anymore energy out, or even energy out remotely approaching the chemical energy in the source fuel, be it: after shave, soda, or pickle juice.  If one has carbohydrates, or hydrocarbons, then one has chemical bond energy that is potentially useable for fuel.  Cooking off the aromatics, and volatiles is a way to get at some of that fuel.
