Thanks to ALL for your help!!
multiplying electricity
Started by that_prophet, July 19, 2014, 05:54:04 PM
that_prophet
GEM (God's Electricity Multiplier) = Miracle motor
Perpetual Motion Plus "machine"
This is not gaining energy out of the air, or from nothing,
-         but you are actually doing some converting (multiplying)
-         the # of rotations with your different size pulley combination.
-         this is how you seemingly break the laws of thermodynamics
You are putting enough energy into your DC motor to rotate this 100cm
circumference pulley –(or as large as you like) only one single rotation.
Then you are using a multiple of pulleys,
of varying sizes to multiply your rotations.
These motors take little to no torque to turn,
so we can easily use tens to hundreds of these pulleys,
to multiply our electricity.
We could do this for any voltage,
and start industries to manufacture these power free electric generators
-         in all of our electric tools + toys.
This is SOOOOOOOOOOOO SIMPLE
The only reason that this has not been used earlier to create free energy, are the billions of fallen angels, trying desperately make sure that we never discover this technology
Free Energy is such an obviously simplistic discovery,
- as well as being extremely easy + cheap to produce,
what is the only reason for us missing this basic idea,
- we have been dumb to this free energy technology.
- - or are forces involved
This technology has been hidden for far too long,
Please, go to this website
http://free-energy.yolasite.com/
+ (please remember, these motors take zero torque to rotate)
     So, you can add as many mini-pulleys as you would like
        To multiply your electricity many times
then you may want to try your hand at producing a digital prototype
on one of the many free electronic simulator software's out there,
that will help quick start the production of electric toys + tools,
and how about everything that runs on electricity,
being reproduced with GEM, free energy power supplies, built into them.
Let's restart our economies,
by building industries that reproduce all of our electronics,
so that they are all self powered. (non polluting)
= First though, is getting rid of all the gasoline motors in our motorized vehicles
and putting a GEM in them.
All we need to do, is have enough faith in His Word
to build these GEM (God's Electricity Multiplier) Miracle motor
THIS DOES INDEED WORK
(think about how simple this is)
(you put power in to rotate one large pulley once)
(you run a belt to rotate mini-pulleys many time)
(then you could add many mini-pulleys)
(each one rotating hundreds of times)
(multiplying your AC electricity)
(YOU MUST GAIN FREE ENERGY)
LOGICAL REASONING
electric motors run extremely smoothly
taking little to no torque to rotate
It takes little energy to turn a one foot circumference pulley,
which can be used to drive a belt that turns a mini pulley
of one inch circumference many times
Madebymonkeys
Sigh.
That's the equivalent of saying use a motor to drive a generator isn't it. That won't work either.
Would you STOP already !!! For over two years now you have been posting the same flawed idea, making the same flawed assumptions. You have been asked many times to demonstrate your idea, or to study the correct mathematics of torque, moment arm and rotational momentum, or to check your assumptions and clean them up. But you refuse. You invoke your Christian faith but that is no help, because your idea WILL NOT WORK and your assumptions and your math are wrong. I can only conclude that you are in the continuing grip of a reality-denying obsession. I suggest you talk to a professional about your problems, and get some help. And I don't mean with the math.
that_prophet
Quote from: TinselKoala on July 19, 2014, 10:38:30 PM
Let me describe a simple project:
You have a 100cm circumference pulley attached to a DC motor,
You connect a belt to this large pulley + 10 small 1cm circumference pulleys,
These mini-pulleys have AC motors/generators attached, (with no load at first)
Now you rotate the large pulley by hand,
This gives you a return of 10 X 100 = 1000 units of AC power
Now,,, try and tell me that this 1000 units of AC electricity,
Does not have enough voltage (electrical pressure)
To rotate your DC motor one time, (all voltage + only a spark of current)
Let me describe a simple project: BUILD IT YOURSELF and you may learn something... at least you will learn why nobody else will build it for you, since it's an utter waste of time and resources.
It is useless for you to continue spamming SIX THREADS with your unworkable device (which, by the way, is a member of a class of devices called "Q-Mo-Gens" by Sterling Allan at PESN).
This scheme _does not work_ and if you would just do a few actual experiments of your own, you might come to realize it yourself. In the meantime, just what is your justification for posting the _same things_ in six different threads? Do you think you'll do anything besides annoy people with your spamming of the forum?
