Thanks to ALL for your help!!
AuroraTek demonstrates overunity transformer at TeslaTech 2014
Started by rukiddingme, August 14, 2014, 12:31:12 AM
mscoffman
Quote from: rukiddingme on August 15, 2014, 02:06:23 AM
Can't find a way to delete a post. Any help?
Thanks.
This is an example of the best you can do, if you catch it in the same day when you can still edit your message;
http://www.overunity.com/14730/deleted/#.U-4O2MVdWSo
I am not picking on user "Freeenergy" here, it is just the first example I came across.
MarkE
Quote from: TinselKoala on August 15, 2014, 08:25:29 AM
This topic deserves further discussion anyway.
Why do the moderators at PESN give time and space to Alek and his bogus claims and failed promises and irrelevant demonstrations, when he is clearly not using his equipment properly and cannot justify his measurements with actual calibrations or explanations as to his choice of settings, while at the same time PESN is  _actively suppressing_ my microQEG demonstrations, even to the point of calling my videos hoaxes and frauds and outright lying about my motivations in presenting them?
Huh? Why is that? If even +one person+ pays attention to my videos and decides to wait until Jamie produces an actual self-runner... that is ten thousand dollars saved, at least, right there. Since James will never produce said self-runner. Yet by denying their readers access to the links and the discussions of the QEG and microQEG that _only_ take place here, on R-G and on the video pages themselves, PESN is functionally complicit in causing group after group to order cores from Torelco before having any proof at all that they will actually self-run, and before they understand the points about reactive power, "OU in VARs", resonant tanks and so forth that I and Farmhand have been demonstrating.
By the way.. Farmhand... I am really excited about your replication of Supernova Mode ! As far as I can tell you and I are the only ones to have demonstrated something like this in our _true_ Tesla-inspired resonant tuned circuit wireless power transmission systems. I would love to see other demonstrations of the same effect from other wireless power experimenters.
PESN gave up most pretense of honest debate in 2011 when they began censuring and banning heavily.  Since then they have become more and more insular.  Your fine experiments don't support their belief system, so they reject them.  I believe the pretense that they offer is they claim your experiments are deliberate fakes.
Pirate88179
Remember, these are the guys that backed Mylow.  Enough said.
MarkE
I had hoped that the Mylow disaster would be a sanity wake-up call for the people at PESN.  I am sad to say that I don't think things have improved.  If someone tells then a story that they want to hear like SHT for example, they buy that story hook line and sinker.  Not to derail, but I wonder how long it will be before PESN figures out that SHT is lying about the kg of water converting to a kg of H2 gas?
Farmhand
SNIPPED:
Yeah it's interesting for sure, with my new setup I'm working towards a usable device but will be testing numerous things before
it goes on the wall. At the moment I'm experimenting with "harmonics" to get crazy activity with very small input. With each
secondary having 28 uH I can tune both as separate 1/4 WL resonators, with a 30 to 1300 pF variable capacitor I can tune the
individual secondaries "res freq"out to over 5 mHz, but I get best harmonic excitement of the secondaries at 1/2 and 1/3 of the
fundamental frequency. ie If I run the primary at 300 kHz I get good activity at 600 kHz and 900 kHz but also at 1200 kHz and
higher.
My local radio transmitter is at 840 kHz and so I think I'll run the primary at 420 kHz and experiment with the 2nd, 3rd higher
harmonics, maybe the fourth as well. I'll try to make some beats by tuning each secondary to a different harmonic and by just
varying the frequency of the two to each other on the same harmonic.
Voltage is low but while powering a small fluro tube I scoped 200 volts RMS and about 4.5 A RMS in the tank at about 180 degrees
(I think), as compared to the fundamental at about 27 to 30 degrees.
That was with both coils though at 600 kHz with 1/2 excitation frequency.
Using harmonics is ok for activity but resonant rise is smaller and heavy loads destroy the harmonic resonance easily. But for fluorescent tubes I think it will work ok, input to get the activity at the higher frequency is small.
So not only can we make a lot of tank activity with fundamental resonance but we can also make a lot of activity at 3 times the
frequency tuning to higher harmonics. Thinking about setting up my big four transformer Toroid and trying for a phase delay on
the current due to magnetization delay caused by core (size) distance between coils on the core and frequency.
Anyway, I'm having a lot of fun.  ;D
