Need Leedskalnin PMH coil winding diagram
Started by magnetman12003, August 15, 2014, 03:06:32 PM
magnetman12003
Hi All,
I am going to replicate the Leedskalnin permanent magnet holder PMH. " Large U bolt used"
Can someone furnish me the CORRECT diagram of which way the  wire coils are wound and
how they are linked to allow a charge to be applied activating the PMH device.  Please indicate clockwise/counter clockwise wind on the diagram.
Can one coil be wound clockwise and the other counterclockwise and if so how are they linked?
Your help will be most appreciated.
sm0ky2
Wanted to show you guys something,
So I just picked a random PMH thread to put this in.
I don't have the real inventors name, some scientist in the 1900's published the PMH
in a journal of the British Royal Society.
We know the device by the name of the man who plagiarized the experiment and made it famous.
So we'll just call it the Leedskalnin PMH...
I was toying around with the two devices on the right side of the picture.
They are both the same, one I removed from its housing.
This is a dc step-up transformer. 1k:1
4.5v@2A
Which translates something close to 4500V @ 2ma (dead short discharge)
I charged the spheres and discharged them several times.
This is 305 (non-magnetic) stainless hollow spheres.
I noticed every few discharges the balls would magnetically "lock"
So I locked them and unplugged it.
These balls are currently under a magnetic loop lock.
I think this proves that an electric flux is present in the loop.
(based on an assumption that such must be present for magnetic induction)
Just wanted to share
sm0ky2
I will eat my words now...
There is no electric flux.
No potential, no charge
But I think now I better understand how this thing works.
in fact I have identified the paramagnetic electric state necessary to describe the PMH.
(using modern theory)
When we magnetize a paramagnetic material, and remove our inducing field
the field created in the material will revert to an incoherent (scattered)  state.
At the moment our field changes, the paramagnetic material gains a magnetic potential.
A potential magnetic field differential between the coherent (magnetized) state, and the
scattered state.
Through a closed loop, if the magnetic resistance is less than the impedance of the inductive
loop, then the magnetized state IS the lower energy state.
It would require energy to break the magnetic loop to collapse the field.
And in doing so, the field energy is released.
(also means that magnets let off electricity as they die at least on the atomic level)
The induction opposes the change in magnetism.
This holds the material in a particular electric state, similar to ferrous interactions.
sm0ky2
The 'two spheres' experiment above can be performed with 3,4 or
any number of spheres, (any shape really, but round surfaces are unique)
even forming them into a complete loop.
Hexagon nuts, or u-shaped metals, toroids, tubular loops, or a single wire.
We can charge them, magnetically, using electrical current (as a conductor)
Or using electrical field (as an inductor) by placing the conductor in the field.
when people say "there is no external magnetic fields"
this is not accurate. With sensitive equipment, magnetic poles can be detected.
However, most of field remains within the conductor.
when one considers the inverse of the inductive constant of the material
we see this system behaves exactly as Maxwell said it would.
I believe someone a little better equipped than myself could easily use this
as the basis for a magnetic capacitor (doc brown would be proud)
The stored magnetic energy, when the circuit is opened, induces an electric field.
when the circuit is closed, it is a capacitor in the magnetic domain.
It is integrable using the magnetic impedance and magnetic inductance.
(1/H) to find the magnetic (flux) charge value
discharge follows modern electrical theory.
