Thanks to ALL for your help!!
Inertia Drive project. RFDD.
Started by tinman, August 17, 2014, 06:20:44 AM
MarkE
Tinman that looks like a pretty reasonable set-up.  You might want to put a a full loop in the flexible section above the hinge, and make that section of hose as pliable as possible so that it does not transmit torque, one way or another to the hinged vertical section.  You might also want to run a pressurized null test by replacing the nozzle with a cap and adjusting the flexible section support for as little net force in either direction as possible.
ingyenenergiagep
Hi!
Where is the inertial drive here? ;-)
M= F x r.
10N x 1m= 1N x 10m.
mass= X kg.
Upside down rocket engine on mass= X kg+ propu force. Propu force= summa mass minus mass.
ARMCORTEX
There is nothing here.
This silly moving machine will not produce a single watt of heat energy or light energy for free.
Tinman is but a fool, his stupidity may cause his family to starve in a coming nuclear winter.
Luckily for them, they will have a cool wiggly device to look at as they die.
''Why Tinman, why, why didnt you listen to ARMCORTEX, you could of bought more bags of rice and fire wood, Im now gonna die because of you Tinman''
''Why didnt you send all our savings to ARMCORTEX, he could have saved us with his superior ideas and superior IQ, but nooo, you didnt listen to ARMCORTEX''
MarkE
Quote from: ingyenenergiagep on September 04, 2014, 12:43:53 PM
Hi!
M= F x r.
10N x 1m= 1N x 10m.
mass= X kg.
The idea is that the thruster propellent is recollected within the system and therefore not expended, resulting in an "externally reactionless" IE propellentless drive scheme.  The faucet is a convenience.  Tinman's earlier test was conducted with a pair of pumps recirculating the water.
ARMCORTEX
Tinman, I see you are spamming the boards everywhere, I cannot accept this insult to the intelligence of gravity device initiates.
I already had an idea for  clever and directable (decoupled) thornton drive, wich needed no gears and was far more solid and could had had a longer arm.
I never even considered it worthy of my time, a mere afterthought, not necessary to me.
And there you are, running around with mere shit as if it was gold.
