Aetheric Battery, New Free Energy Source From Aether!
Started by tinyCoder, September 10, 2014, 03:51:09 AM
tinyCoder
Hello people on the other side of the earth. May God bless you and your work you do to make this planet better for living.
I want to share some ideas with you about a new device which we found it working, and better to generate power without using any other sources like sun or wind power, or even magnets. It is only aether.
[attached1]
Aetheric Battery, as the inventor named it, is a revolutionary device which has not any moving pieces ... and it's electrical power generation continuing forever! It depends on two main ideas, the pyramid power and the electro-dynamic power of water, which i will explain in steps later.
[attached2]
It is very easy to build and has no electric circuits or such complex attachments.
[attached3]
We are translating this project to English and trying to share it ASAP.
Down there I posted some links from our website, you can use the (G) button in the header to translate the pages meanwhile we come with the full translation of this project so soon, but to be honest we needed to share some subtitles with you to know how do you interact with such kind of topics here.
Here is a video showing the device (In Arabic): http://www.youtube.com/watch?v=57QUZ2-J5xc
Here is a description in our website to this device: http://alpha-sci.org/showthread.php?t=50
And here is a full description about building this device step by step: http://alpha-sci.org/showthread.php?t=1372
Another friend from Iraq build it successfully: http://alpha-sci.org/showthread.php?t=1576
This device has two versions as the inventor said, and it provides a high ampere ready to use without any modifications, the small prototype you see in the images provides 12 to 15 volts, bigger sizes can generate clean 220 volts with high ampere too.
Getting back soon.
Void
Interesting. Do the pyramids really make a difference in power output if pyramids shapes are not used?
profitis
That's a very steady current.are you sure there's no galvanic corrosion action here
tinyCoder
Quote from: Void on September 10, 2014, 09:33:17 PM
Hello dear "Void".
Well, the inventor said that he removed the pyramids in the second version of the device (which i didn't reach yet), but in this first version we used the unlimited low-frequency oscillation of pyramids to affect and order the water molecules (ORMUS WATER which is more sensitive to such tiny vibrations of pyramid power) which in the Lyden Jars (http://en.wikipedia.org/wiki/Leyden_jar), so it means we can use sound vibrations instead of pyramids.. but this will cost energy, and this is something we don't want in a FREE ENERGY DEVICE. The whole idea depends on the  "Vegetative Growth Of Power".
See attached file, coming soon with more details.
tinyCoder
Quote from: profitis on September 10, 2014, 09:49:52 PM
Hey dear "profitis".
I don't think there is, the Lyden Jars charges a water battery (with mineral slices) which is connected to both jars, an electrical charge starts to materialize in a specific time depends on the sensitivity of ORMUS water and the size of pyramids and some other things will be explained later.
