Aetheric Battery, New Free Energy Source From Aether!
Started by tinyCoder, September 10, 2014, 03:51:09 AM
magpwr
Quote from: profitis on September 12, 2014, 03:30:10 AM
Yeaaaaah mags.but the document says both plates are stainless steel.so let's put our science-logic cap on and try figure this.we have 2 leyden jars feeding 2 steel plates submerged in water.now let's take your typical leyden jar power (kilovolts + nanofarads) and convert and see if we can get farads + 2.5 volt? Where's les banki?
hi profitis and everyone,
I have added my findings below.
I just noticed both plates are stainless steel,strange.
But a photo in the middle of web page shows zinc/copper.It was misleading before doing translation.Interesting experiment.
I finally understood what is happening once i saw this sentence after translation-
"exposing the water to the sound vibrations or magnetic fields (mobile or fixed), or even specific electromagnetic fields."
I have done research in the past related to water which is related to healing.Yes healing.
There was a research done in Taiwan where a scientist proof that water is able to store memory.
For example if you have done research in wicca or occult there is also a part which is related to charging the water.
Before you drink the water you send thought to the water with the intention to heal.
If you think holy water is fake .Then look harder at the molecular level
At the molecular level under the microscope there will be tiny crystal formed in the water as discovered by the Taiwan scientist."Water memory" if i recall correctly.
If you studied little about minerals eg:quartz the main portion is "fossilized water".
I think what the scientist in the middle east have done is "energised the water" with certain vibration.The water will retain and produce the vibration like eg: holy water.
The water combine with the pyramid and the necessary connection provides power to the bulb.
Let you know the history of battery "The first battery was discovered in Iraq 1200 years ago.It was used in electroplating.The source of power is lemon juice."
Another more wierd discovery in China there was this 2000 year old grave where a ancient walkman was discovered.The device source of power is smokey quartz and it is connected to the  ear with a ancient headphone via copper wire.The scientist whom cleaned the device found that it was still working after 2000 years.It was producing Chinese funeral like music.
(I was trying to find the picture of this device for ages.The article first appeared in my newspaper more than 20 years ago which there is a section for foreign news.)
tinyCoder
Quote from: profitis on September 11, 2014, 07:44:45 PM
Incredible.this will put duracell out of buisness those are filament bulbs. Must be around 20 milliamps! Hard hard to believe @coder did you see this thing in action before?
Hey profitis,
The glass version is not powerful enough but built to show the structure of the device, the gypsum one (about 6 to 7 cells in the wet battery) could light 2 bulbs of 6 volts and 5 watts.
tinyCoder
Quote from: magpwr on September 12, 2014, 12:06:45 AM
Hi Profitis,
The bulb would need around 200mA for its size.
I am not too happy about using salt water which would errode copper&zinc electrode.
we need to find out if using these 2 electrode with salt water would produce similar output.
If it is similar output then the experiment shown in video is bullshit but not fake.haha.
Hello magpwr,
NO SALT WATER HERE AT ALL.
Just clean and powerful water processed with ORMUS TRAPPERS to be more sensitive to the low-frequency waves of pyramids as descriped in the file.
profitis
Let me try to get to the scientific fundamentals here guys.kelvin's water dropper and leyden jars are capable of accumulating thousands of volts.the question is: what is going to happen if we put thousands of volts across two plates in water?what is generating the static charge at such a fast pace?
tinyCoder
