Aetheric Battery, New Free Energy Source From Aether!
Started by tinyCoder, September 10, 2014, 03:51:09 AM
profitis
tinyCoder
Quote from: profitis on September 12, 2014, 06:59:28 AM
Does it work anywhere anytime coder?
Yes dear, anytime and anywhere, but as the inventor advised, it should be isolated from any electronic or magnetic waves, or to move around it, that's because the devices stops working when the aetheric field around it is turbid, and noticed that the energy grows in it and increases to a specific amount depending on some conditions I previously told you about.
And one strange thing also, he said that if the load is bigger than what the device can handle (means trying to put 3 bulbs instead of 2) then all the three will stop lighting, and as we all know this should not happen in the normal experiment as the three bulbs should light on but their lighting intensity will decrease.. but that did not happen.
profitis
Thank you coder.it means when you put the 3rd bulb in a row the voltage across the steel plates drops to below electrolysis voltage sustainability.those bulbs are being powered by a inverted electrolysis/ fuel cell.they are leaking the charge off the fuel cell while electrolysis proceeds.this is one way to convert high voltage/low amps to low voltage/high amps at an extremely high efficiency.the question remains:what is charging the leyden jars at such a pace
tinyCoder
Quote from: profitis on September 12, 2014, 07:35:17 AM
No, this small version took about few days to start producing the energy.
conradelektro
