Aetheric Battery, New Free Energy Source From Aether!
Started by tinyCoder, September 10, 2014, 03:51:09 AM
magpwr
Quote from: conradelektro on September 12, 2014, 10:08:49 AM
@tinyCoder: thank you for replying. I hope you understand that people (and me) are sceptic, because you make an extraordinary claim which needs extraordinary clarity to understand it.
What I see so far:
- There are at lest two metals involved (copper and the other is may be steel) and the two metals are connected by "Ormus water". Could you please clarify what metals there are and how they are connected by water (water in the jars and water through a pipe to some glass tube)?
- Ormus water is an esoteric term, fine. Could you specify from where you got the water before it became Ormus water? (I suppose it came from the public water supply?)
- It is very important to establish in as much normal electrolysis comes into play. That will be the first thought coming to the mind of a sceptic, so you will have to address that very methodically. First, just specify what metals come into contact with the "Ormus water" and all the places  (jars, tubes, other containers like where I see steel plates) where "Ormus water" can be found in the contraption.
The better details you give, the more people will stay in the discussion and might even build something. At the moment, frankly, you explanations are very feeble and incoherent. The tread will soon wither away if you keep going like that.
Greetings, Conrad
hi,
"Ormus water" this is something which did not exist in the past.This is new to me.
All i know there is such thing as "Ormus gold powder which exist as white powder" which was found at certain excavation sites in Egypt.This was used by high priest or sorcerer to enhance Psychic ability.
It was to be placed under the tongue in tiny amount.
wistiti
Hi
my personal opinion is at this point is to let Tinycoder finish the translation of the information of this device. After that every one can replicate it at low cost and then ask question and comment whit the result they have and elaborete theories...
In this kind of forum it is became a rare thing to see people how share the work they do with elaborate information and ask nothing in return...
For me it speak a lot!
Kator01
Hello,
retired scientist Dr. Milewski explains his model of ORMUS-Atoms:
https://www.youtube.com/watch?v=efZ_661eXiQ
Ormus can be gained from either seawater or ordinary tapwater: Vortex and magnetic trap
http://www.scribd.com/doc/77393734/Magnetic-ORMUS-Vortex-Trap
http://www.subtleenergies.com/ormus/tw/m-seeps.htm
Dr Milewski´s magnetic trap-design:
http://www.subtleenergies.com/ormus/tw/traps/ttplans.htm
Kator01
profitis
Guys the only important thing is the ph of that water.if its acid then it will corrode steel.if its neutral then its not really a problem.if its alkaline then its not a problem.if there's 2 different metals contacting the water then its a huge problem.the pdf indicates that both plates of the accumulator are steel so I don't imagine how this can power a lightbulb.we need more info
conradelektro
Quote from: tinyCoder on September 12, 2014, 08:31:49 AM
Metal... Mineral .... maybe the translation of me is not good enough, but the one you are asking about is ===  copper  ===, and it is covering the jar. The green cylinder is a normal water tube filled with === gypsum === and it plays the part of the salt bridge in the normal battery.
Sorry, think I should be more clear in the next part of translation.
Getting back soon.
The quote is the reason I am waffling about two metals, there are steel plates, silvery metals and now we hear there is also copper. Copper is not silvery!
It should be possible to list how many metals are present and where. I should be possible to specified where the Ormus water is and how all vessels (jars, little hoses, green cylinder) are connected with wires and little water hoses.
"Normal water" from the tap is good enough to cause electrolysis if two different metals are present, even in different vessels, as long as water can flow from one vessel to the other. But Gypsum can cause acidity, it is calcium sulphate, CaSO4.
May be tinyCoder can telt us from which language he is translating from. He could be helped. This forum has members with many different mother tongues.
So, we have
- two metals (copper and something silvery, may be steel),
- water in several connected vessels (jars, little hoses, green cylinder) and
- an acid from CaSO4 (from the gypsum).
You will allow me to guess what it is! Of course vibrations from the pyramids are not ruled out. Also Ormus is a god worth being worshipped. A god can cause miracles.
Greetings,  Conrad
