Magnets that goes against Gravity that repels each other Motor/Generator !!!
Started by teslaedison, September 15, 2014, 07:34:08 PM
teslaedison
Hello all here,   I figured out that North and North repels each other that also can be made and used to make a center magnetic motor that is also connected to a disk at its 90 degrees angles and at the ends of the disk shape are many other magnets that rotate in the circular formation and is also repels with the stationary of the outside magnets diagram to this so hope someone can see this with the two diagrams I am going to put here and possibly someone can make it as well here.   If you have any questions to reply back to me here thanks.  The same outside stationary magnets will also repels the center magnets of the motor but also repels the magnets that are connected to the disk at its 90 degrees angles as well at the same time as a one unit Motor and Generator too !!!
Thomas C.
teslaedison
I totally believe now that my device can and would go at light speeds now because there are no metal to metal frictions whatsoever and plus would not fly off its axis either !!!
Thomas C.
vasik041
Quote from: teslaedison on September 15, 2014, 07:38:36 PM
Thomas C.
Next step - build and test it  ;)
teslaedison
Yes I believe I got it and can be changed how the metal rings also on both sides and quess what your producing on one side a North electrons and on the other side a South electrons on there outside that attracts each other but the distance also plays apart in that also so hope others here can see this too ?   Oh by the way God actually showed me this diagram too all here so he is 100 percent real is why on a small scale too !!!
Tom
Cherryman
This reminds me of a few years ago. From the top of my head:
Some guy on the GLP forum claimed hey made a setup from a handful of magnets.
It was hollow, and accidentally while constructing a magnet got in the middle and started spinning...
Speeding up..more and more.. he even talked about a kind of fog or mini cloud forming around it..
It was fascinating, even a little picture.
Ofcourse he got ridiculed and dissapeared.
Edit:  I got the topic http://www.godlikeproductions.com/forum1/message1359379/pg1
