Regular Transformer connected to the Bi-toroid Transformer (possible issue)
Started by taleo, September 20, 2014, 01:51:46 PM
taleo
Hey guys,
I've replicated the BiTT with successful results, however I found one issue which I could not explain. I have a Kill-Watt-Meter which is just a device that measure the power being consumed off the grid from an appliance that you plug into the wall outlet.
So I hooked up a Kill-Watt-Meter to the wall outlet and connected a regular step-down transformer. Then I connected the output of the regular step-down transformer to input of the BiTT. When I add load to the BiTT I measure overunity from the input of the BiTT to the output for the BiTT. However, when I see the Kill-Watt-Readings from the input of the regular step-down transformer, I see more power being consumed than the output of the BiTT.
I can't come up with an explanation as to why. I am wondering if somehow the apparent power of the input of the BiTT is being somewhat transferred to the input of the step-transformer causing increased power consumption. I don't know if that even makes sense but I just can't figure out why on one side my measurements say one thing but on another side they say something else.
Has anyone had this problem before?
Thanks.
taleo
An elaboration would have been appreciated. But it's okay, I figured it out. There's a 90 degree phase shift from the input of the step-down transformer to its output, which is the input of the biTT. The input of the biTT is seen as an inductive load to the step-down transformer so it doesn't matter what the power factor is on that side because its seeing the Apparent power as the True power.
That sucks though, there's gotta be a way around it. I'm gonna look into it some more.
Neo-X
Good job taleo. Can you post screenshots of your bitt? What kind of core did you use?
taleo
Thanks Neo-X. I've attached a photo of it. The top core is silicon steel. The bottom one is metglass with double the cross sectional area. But in reality I think it should be based one surface area not cross-sectional area because ac magnetic field travel on the surface of the core, that's how the wires get induced with the voltage. And I think the name for these cores should be called field divergence cores. It sounds more appropriate but I don't really care I'm just thinking out loud.
