Magnet Myths and Misconceptions
Started by hartiberlin, September 27, 2014, 05:54:29 PM
0 Members and 23 Guests are viewing this topic.
Turbo
Exactly.
First the man denies it's existence, and then posts a picture showing it's existence.
And off course, as always, the were is your part.
I said what i wanted to say and i will leave it there since i am convinced it is enough to communicate the message.
I know it's hard to grasp the idea of field lines between all conducting objects in the universe but this is exactly what makes it so interesting because it would imply that every mobile phone or tablet or laptop or in fact any conducting object is already connected to one another by nature... and always has.
On another note this opens up more possibilities because you can work from open circuit to open circuit which is impossible where closed circuits are used, and this is also the area that has got room for 'external input' and would imply that a change of potential on one conducting object has to influence all other conductive objects in the universe but i better not go there it just too much.
Newton II:
QuoteI appreciate your patience in replying to ignorant questions of ignorant people like me.
An ignorant person may think that head is full of ear wax which comes out of hoels in ears or it is full of mucus which comes out of holes in the nose (nostrils) just like water comes out of a pipe connected to a overhead tank.    There is nothing wrong in the logic.  But learned people like you should tell them that there is brain inside the head and these things come out of some other place.
You don't have to put on a show and play the wounded dove.  Nor do you have to play act with the fake patronizing attitude and the fake self-depreciating comments.
Do you want me to spend an extra 1/2 hour so that my response is just oh so perfectly politically correct for your sensitive ears?  Do I need to choose every word carefully so that you are not "wounded" by my statements?
How about we just get real and make our points without any fake drama?
Quote1) When dirac spoke about 'anti matter' other scientists suggested psychiatric treatment for him. But later his theory  was proved
    experimentally.     When something called as 'anti matter' exists, what is wrong in thinking that corresponding 'anti-field' also exists?
I hate these illogical connections that people make, and I have observed you do it many times.  "They said the Titanic would not sink but it did sink.  Therefore electric discharges could be plasma leaking in from an alternate universe."  That's nonsense and you should try to avoid that false logic.
QuoteLenz's drag (as mechanical force) comes into picture only when there is physical relative motion between coil and magnetic field. Since
    both coil and magnetic field are rotating along with sphere with no relative motion between them, there is no chance of lenz's drag (as
    mechanical force) in that scheme.
The clip and formula is about a moving point charge.  You are talking about a stationary rotating sphere of charge.  Do you see a problem there?
QuoteSun is a huge positively charged sphere rotating on its own axis and completes one rotation in 26 days. Considering  the size of the sun,
    the velocity developed at its outer surface should be very high.    Does  sun  develope a huge  magnetic field  around it due to this
    motion or high temperature of sun prevents it from producing magnetic field?
The thermo-nuclear-reactor sun has nothing to do with what we are talking about whatsoever.  They said the Titanic would not sink, you know.
QuoteI don't see anything great in humans building bridges and skyscrapers becuase even birds and insects are capable of  building
    nests/hives to an engineering class just by intuition.  Intelligence in humans is also a form of intuition and they have to thank God for
    giving them that intuition.
That's another nonsensical point that does not advance your argument at all because it is irrelevant to the discussion.
You supplied no diagram and no equivalent circuit and made no attempt to truly describe the operation of your proposed mechanism.  And to repeat, your proposed system has nothing to do with a moving point charge, and a moving point charge is supposedly the root from which your argument is made.
The issue with you is the propensity to make connections between ideas when in fact the connections are not there.
If you want to completely ignore the discussion about a moving point charge, and discuss how a rotating sphere of charge with some kind of coil configuration can give you a generator with no Lenz drag then fine.  Let's completely forget about a moving point charge and start from scratch.  If you are willing to provide the physical and schematic diagrams and make a timing diagram that shows how the electric circuit allegedly works, then fine.  But if you can only offer pie-in-the-sky prose that describes something from your imagination, then forget it, I will not be interested.
I can sum it up with three words, "please be real."
Webby:
You won't comment on that fool because he is a fraud.  You want another sign that he is a fraud?  Take a look at the "job openings" slide that I just captured today and posted here.  I am willing to bet you that the "job openings" are the same now as they were two years ago.  What does that say?
It says that he is a fake company and the job openings are a pretense to make it appear that he is a real company to lure in gullible investors.  He is not hiring anybody, the slide on his website is a LIE.
Sorry for going off-topic but it at least does fall under the "myths and misconceptions" umbrella.
Quotea point charge, these things are taught as if they actually exist
Did you ever take a physics class where you do the derivation showing that a sphere of mass can be modeled as a single point of the same mass?  These are intellectual "leaps" that help you to understand the real world.  They do not teach you in school that field lines are real lines, real physical things.  I don't know where you are getting that from.
Your argument is similar to the case when you tell someone that an inductor is actually a wire of zero resistance, and you can get a voltage across that zero-ohm wire.  Because they can't understand the concept of inductance their eyes glaze over and they accuse you of talking nonsense disconnected from the "real world" of inductors with resistive wire.
Anyway, naturally this thread only reaches a few eyeballs.  Some time within the next 24 hours you will see an uninformed person make a posting that includes a myth or misconception about magnets or magnetism.  It may even be someone that read this entire thread.
sparks
  I first figured out how current through a static magnetic field forced the current carrying metal to move by reading a very old book published around 1901 dealing with electromagnetism.  It was a practical guide for electric motor technicians and engineers.  Below is a picture I drew up fast to duplicate the much better diagram from the book.  The magnetic field is like water blowing across the ocean surface.  In the diagram this is from left to right.   The conductor current is flowing into the page.   (could be out long time since I did any right-hand left hand stuff)   A circular flow of magnetic current is created as indicated by the arrow around the conductor surface.   The rotating current increases the total magnetic pressure on top of the conductor whereas it decreases the magnetic pressure below the conductor.  Therefore the conductor moves from the top of the page to the bottom.  Something like an airplane wing or a sail.  The wind because of it's viscosity has to travel faster around the bulge in the wing or sail.  This decreases the pressure.   The lower side of the wing or the more or less flat side of the sail allows the wind to flow unimpeded and at a velocity less than the air traveling the bulge.  The split stream converges at the trailing edge of the wing or sail at the same velocity as the bulk flow of air relavent to the craft.  Anyway the pressure is greater under the wing than it is on top and this lifts the craft up as the ambient pressure continually tries to fill the partial vacuum created by the fast moving air.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
CANGAS
Quote from: TinselKoala on October 08, 2014, 10:43:23 AM
Sure, and a topographic map shows that the Earth is made up of horizontal layers precisely 10 meters apart.
Turbo, you are pushing the same line of mistaken BS that your puppetmaster pushes.
There is NO "FIBROUS STRUCTURE" to the magnetic or electric field. "Field lines" are precisely defined mathematical entities that are useful for computation but there is no corresponding physical structure that is a "fiber" of a magnetic or electric field.
Iron filings and ferrofluids do not "mark the shape of field lines", they assume least-energy configurations by orienting the long axes of the particles and clumps of particles along the local gradient of the field. People who do not understand the mathematics see these patterns and assume they are seeing some kind of map of "field lines". Sure, and if you pour water into a depression in the ground, the top surface of the water will mark the level of one of the horizontal slices of the planet that a topo map shows you.
And before you make your assumptions about who has done what with what fields, perhaps you should do your homework. Where are YOUR demonstrations of electric field phenomena? Where are YOUR static machines, your "megavolt Tesla coils", your demonstrations and references that back up your silly claims? You are keeping them very well hidden.
Do you see any magnets, coils, etc that are responsible for what is happening here?
http://www.youtube.com/watch?v=OxEpSX2Hd54
Well, it's like this.
When we construct a model of a phenomenon, we may, or, may not, happen to hit upon  the exactly right visualization that will coincide with what we see when we look with clairvoyant vision upon that phenomenon and see it in its intrinsic real reality exactly like God sees it.
So, if the Faraday model of field lines proves to work out to give the theorists and the engineers and you and me and all the rest of us good and useful answers, then we, still in our non-clairvoyant bewildered mere human condition, have no good basis to say that the field line model is not real. It may be real or it may be fantasy, but if it works, then you don't have any case for claiming that it is not real.
And likewise, I do not have a conclusive case for saying that it is real because I am just so sure that that is how God sees it.
You cannot prove one way or the other just like I cannot prove one way or the other.
Perhaps you disagree.....
G'day mate
CANGAS 86
