Magnet Myths and Misconceptions
Started by hartiberlin, September 27, 2014, 05:54:29 PM
synchro1
Hey, that RWG  Ed Leedskalnin trick looks just right for a "Trash harvester".
What does Ed Leedskalnin's "Impulse Magnetization Effect" have to do with Tesla's early wireless transmitter pictured below? This transmitter broadcasted a magnet wave thirty miles from downtown New York to West Point. It transmitted power along with information. The top portion of the radio contained a spark gap that created a violent "Field Collapse", similar to the one Russ produces with his one wire coil, from the battery below.
synchro1
Here's a schematic of an early spark gap transmitter:
synchro1
What would happen if we use two identical clip leads, and form two one loop coils? We loop one lead so the clips are positioned in close adjacency like a spark gap. We run the wire through the hole in the board and assemble the six nuts like Russ did. Now, we take second clip lead across the room to a battery, loop it and spark a field collapse. What are the chances the spark will jump the gap in the second wire and lock the nuts with the same Ed Leedskalnin "Impulse Magnetization Effect" at a distance?
tinman
Quiz time.
If a steel ball is place near a magnet on a flat table,why is it attracted to the magnet?. I mean dosnt the steel ball carry the field of the magnetic pole it's closest to,dose it not become an extension of the magnet/. If so,then why do two like poles attract.
synchro1
"In 1888 physicist Heinrich Hertz set out to scientifically verify Maxwell's predictions. Hertz used a tuned spark gap transmitter and a tuned spark gap detector (consisting of a loop of wire connected to a small spark gap) located a few meters away. In a series of UHF experiments, Hertz verified that electromagnetic waves were being produced by the transmitter. When the transmitter sparked, small sparks also appeared across the receiver's spark gap, which could be seen under a microscope".
What would it take to recreate this spark gap transmitter reciever of Heinrich Hertz, to transmit and receive Leedskalnin strength locking force? A larger battery perhaps?
Look at Hertz's first receiver below. It's just a one wire loop with a spark gap, just like Russ's Impulse Magnetizer coil:
I may be, once again, reinventing the remote car door lock!
