Magnet Myths and Misconceptions
Started by hartiberlin, September 27, 2014, 05:54:29 PM
EMJunkie
Quote from: EMJunkie on January 03, 2015, 05:27:47 PM
Plus one more: (Thinking very Hard kiddies, what is the Natural Current Sheet?)
This one is from NASA just in case you're STILL worried that I have not provided enough SCIENTIFIC PROOF that there is an Equator, also known as a Bloch Wall:
EMJunkie
In Any Court of Law, that verdict would have been already drawn. Bad Science would be paying Damages and me, well I would be in my lab, experimenting on BASIC IDEAS THAT WORK WITH SOLID SCIENCE TO BACK IT ALL UP.
Time to make changes People! Time to Clean our your Clogged Cavity's!
Like I said a few days ago:
"Experimental EVIDENCE IS UNDISPUTABLE NO MATTER HOW MUCH RUBBISH YOU TALK. You dispute EXPERIMENT You're a fool!"
Maybe if I had a OU.com score of 10,000 I could Bullshit People up the garden path! I would rather use REAL Science and get somewhere!
Kind Regards
  Chris Sykes - hyiq.org
MarkE
Quote from: EMJunkie on January 03, 2015, 06:22:23 PM
Kind Regards
The most appropriate term for what you are espousing is:  face palm.  It is worse than wrong.
tinman
Quote from: MarkE on January 03, 2015, 12:07:26 PM
Tinman, the fact that iron filings magnetize is exactly why they are a good indicator of the the magnetic field orientation and strength.
If you want to test your hypothesis, then that is easy:  Go purchase an analog Hall effect sensor and probe the field of a dipole magnet or any other magnet shape you care to look at.  Or you have a large dipole, like a long wooden dowel or plastic rod with a winding along its length, then you can just use a compass.  The figure eight idea you promote would cause the compass needle to turn 90 degrees at the dipole center when held off axis.  That does not happen.  Held off axis, the compass will always point most parallel to the dipole closest to the dipole center.
The strongest outer field strength is at each pole end of a magnet at the outer edge of that pole,and the most concentrated field is at the center of the two pole ends(what would be the middle of a rod magnet for EG). The figure 8 represents the field strength quite good other than it would need a dip in the center of the top and bottom peaks. You dont need any flash hall sensors,all you need is a simple fram,a spring,a hinge and a good size nail or steel rod. The compass also shows exactly the pattern of a figure 8 when running it down the length of a long rod magnet.
EMJunkie
Quote from: MarkE on January 03, 2015, 07:10:30 PM
And this MarkE is your Scientific Rebuttal?  You've proved debate is past helping some! Some are lost, very lost!
Kind Regards
