Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
IronHead
Let me rephrase this, DUDE ITS OK FOR YOU TO DO IT.
You dont want people doing it that way if there is a failure , get it?
Everyone else that is not a master mechanic or have an installed HHO system  don't hook to break booster period!
Here is a close up for yaz, yup I am shaking abit . This is a lot of HHO in a glass bottle with alligator clips in the zone , DON'T DO THIS!!
http://www.youtube.com/watch?v=DoEXaNnBRPo
h20power
 ;D Now thats sweet, great gas production Ironhead. How many amp you using? I am now making the electronics and a new Myer's type cell. The EDS cell (Joe cell) is just about done, getting great results with it. Lost of charged water that is holding a charge for more than 36 hours of .34 volts. @ .76 volts at 24 hours. It only takes .2-1.06 amps to run the cell so I will leave it hook up. I shocked the crap out of me when I just reached in and grabed the tubes, just like a capcitor, it released it's charge all at onece and was over quickly, thank God. The Myer's type cell is very different in the way it needs to be constructed, plus the electronics should only take 100m-6max amps to produce large amounts of gas with no salts of any kind added to the water. Salts added to this kind of set up just messes the whole thing up. When I am done I will hook them both up to engines, so it will be a two cell system. Magdrive has a four cell that's doing great things, and this two cell will do so as well ;).
Moab
Here is another Ironhead style glass HHO test run, Pure tap water nothing addad. 1/8'' rods left Pure stainless right Pure tungston. Full wave bridge 109V/35A DC. Water temp was from 150-180F during the run. Best temp is between 140-170*F Start amps 1.6 from room temp-150F .06amp after. In the vid the water is a little to hot but you get the idea. Ironhead knows his stuff. Once you get to 140* things heat up real fast. A cooling devise would be needed for extended runs. Still for the amps the best HHO for the money. yes its HHO and it dose pop!
hartiberlin
Hi Moab,
are you sure, it is HHO gas coming out and not just steam ?
Maybe the water is just boiling ?
It reminds me a lot of water experiments I did,
when I used 2 Tungsten rods in Water with K2CO3
added...
Without the K2CO3 it would have looked like this.
But then the bubbles were only steam, like cooking and boiling water
generates bubbles..
2. There is a video on Youtube from the same
poster SGIHUNTER ( Is this our user Ironhead ?)
That shows an amazing cold fusion arc under water and claims
overunity heat output.
Have a look at this, it is said to need only about 12 Watts input:
http://www.youtube.com/watch?v=ZeTQW2pH2Oc
Regards, Stefan.
hartiberlin
Okay, I should probably move this topic to a different thread,
but as it seems to come from user Ironhead I let it stay here for a while
now.
Here is another video of the cold fusion arc:
http://www.youtube.com/watch?v=RICa4OW38bI
He says in the desciption:
A closeup video of the hydrogen plasma surrounding the tungsten cathode in a plasma electrolysis cell. Basically it's the surface of the sun in a beaker.
With about 150 volts DC applied to aquious sodium chloride elecrolyte through tungsten electrodes. The cathode is made to have a much smaller surface area than the anode so that the hydrogen produced on it surrounds it and forces the current to arc through it, turning it into plasma.
