Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
h20power
This is my latest design, I will powder coat the surfaces with titainum or platinum. Platinum is the best, but it just too costly, so I started looking into electro plating it.
IronHead
True and thats why you never start the reactor without the engine running first that creates your vacuum to remove the gas . The little bit that is in the hoses if exploded would not produce much more than a firecracker effect.
But I have built this unit to have a blow off lid with compression rubber seal. I did this because I have had a few pop when on the test bench. Also all internal parts are solid wielded rod and plate. The only wire connection is outside of the reactor.
h20power
Your use of titanium is very impressive that's second best only to platinum. Question why the use of silver? Silver reacts with oxygen to fast doesn't it. What have you seen in your models? They don't erode out? Well, we have a lot of work to do in getting all the cars on the road fitted with our models. The tubes I use are steel reinforced and not to badly priced. http://www.sisweb.com/vacuum/sis/steelhos.htm
IronHead
Not using titanium , I am using tungsten.
The silver show some sign of pitting but it has not fallen apart yet.
The only other material I have found to replace the Silver is Nitronic
Stainless in the latest experiment.
So this next version will have some new ideas.
I have also found some Tungsten punched screen
on the net I am inquiring about for the next system.
Moab
So this is where you guys are hanging out. Very nice reading guys! i love the concept!
Just built my first reactor a week ago with some pointers from our Mr.Ironhead. And i must say it is a real beast! works very well After i scaled it down a bit. It still makes far more than is needed to run your family auto. I used high grade stainless the same thats used in nuke reactors for high pressure steam and tungsten. Since it is my first i have nothing to compare it to other that what videos I've seen on the net. But i can tell you this thing blows away any Joe cell video i have seen, I'll shut up now and let you pros have the floor again. Nice work guys! Much appreciated! Moab
