Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
IronHead
Glad you enjoyed the configuration Moab.
You had to scale it down. Might I ask what
it would be used for in a seemingly small version?
Just curious
h20power
Hi everyone, Well I have come under attack from someone or someone(s) and my home computer is nolonger able to open this site. I have been getting multiple attacks of viruses sent at my computer, guess they didn't want me to keep giving secrets away. So heres a big secret on the Joe Cell and how it is able to work without being electronically connected. It has to do with the self ionozation of water, for even the purest water will make voltage on it's own in about 10 hours. This is to say that it will produce hydrogen and oxygen on it's own. Now when you charge the water this self production of gases increases, all one has to do is too draw it off with a vacuum great enough to overcome the vapor pressure of water. This vapor being drawn off will have a much higher percentage of hydrogen and oxygen being produced. How is this possable it's the hydronium ions, they can only exist in liquid water and not in water vapor. Charged water will maintain approx 1.4-1.5 volts by it's self for about 18hours to keep it charged one only needs to hook up a 9 v battery to the unit. For some reason if you hook it up to a 12 v battery( car battery) it will drain it bone dry. I think it has to due with current availabilty, the more it can take the more it will take, and it can't take much from a 9v battery. I hope the moderator reads this and looks into just who is attacking me. Now as an added bounse if you bring the negetive from the engine too the positive cell you get the magentic effect of oxygen because it is paramagentic. Make sure they don't touch or you will ground it out or sparks will fly, my new design incorparates this into it's design, on this page. They want a war now they got one. This is it everyone now all can take advantage of the secrets of water. Please pass on the word. And a safty note all of these types of cell or tanks need to be drained from time to time for they will build up D2O because for every gallon of water .015% of it is D2O and this will build up over time so just drain it off and the cells will keep working great, again my design has this already planed for. Again make sure you all pass this on, and someone please find out who is attacking me so I can take care of them. Bye for now h2o power............ ;)
Moab
Quote from: IronHead on February 14, 2007, 06:43:14 PM
Just curious
Sure
The components I had on hand was 125 amp varyac and 500amp 100V DC full wave rectifier. (welding/plasma cutting supply's) Well as you can guess it was far too much :o ! So i obtained more suitable components to achieve what i was looking for. scaling down was the only option. 30amp varyac/ 120VDC full wave much better. Moab
pg46
Hi All-
Here is a copy of a note from H2Opower- It's similar to what he has posted above. Seems he has some recent problems with an attack campaign against him. So lets pay attention to what he is trying to tell us. Here is his note-
"HI, yes just water and it also helps to use h2o2 hydrogen peroxide. Well, this is a war I have been shut out of using this site from my compter and have had mulitpul attacks of viruses sent at me. Charged water is another key to getting it to work better, if you want to know I will now point you in the right direction. It has to do with the self ionzation of water, when water is charged a lot of the vapor given off is strait hydrogen and oxygen gas. One needs to make enough vacuum to pull off the water vapor and you will get lots of hydrogen and oxygen gas with it. That's the secert of the Joe cell that's why it will work even if it is not electrically connected. It has to do with hydronium ions, but that's getting deep into it. Some one has started a war on me because I have found out all the secrets. Please post this on the site for me as to tell other what I have found out, okay? Thx"
IronHead
pg46
Tell H2opower
Its not a war on him . The forum just has a virus/trogen and to use Norton or other anti virus tool to remove it.
