Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
Grumpy
QuoteJust Build It!
nuff said...
EDIT:
Anyone having any knocking issues with this gas?  Hydrogen itself has a POS octane rating, but I suspect HHO is different.  CO gas, like from an aquafuel generator has an octane rating of like 120 - very sweet burn  - just a little toxic to breath :-)
        -Frank Edwards
IronHead
So far all computer controlled cars will retard the timing ,no need to adjust.
Ping is from timing and flash point difference with new fuel mix.
Also disconnect Oxygen sensor or install a cut out switch and switch off when running HHO  .Computer gets fooled when  high oxygen is present.
If you have old non computer carb car then retard timing just a couple of degrees. This will have to be done by ear to stop any ping with high HHO production systems.
Now if you run pure hydrogen we are talking about 7 degrees and without the oxygen you will have a horsepower drop . But with HHO the Oxygen content will increase HP.
Just Build It
   IronHead
Grumpy
Hmm.
My boat has a 454.  750mm carb (so-so heads won't take anything bigger).  Gas hog.  Lots of room under the engine cover.
        -Frank Edwards
IronHead
There you go ,Electrolyze that bad boy. Do a big ass box system or something.
Anyone else out there?
Lets get some HHO systems running ,its so easy .
JUST BUILD IT
  IronHead
hanker886
Quote from: IronHead on February 23, 2007, 11:43:43 PM
Just Build It
   IronHead
IronHead,
When Oxy sensor is disconnected, will the computer put out a steady volume of injection? How do you regulate the volume of gas needed with various rpm?
thks
