Sum of torque
Started by EOW, October 12, 2014, 05:36:02 AM
dieter
I would have to make them, with wood and saw, and a couple of inline-skate ballbearings, probably I go and get some plywood this evening :)
Can your simulation software export animations? That would help a lot. Also, looking foward to see your build!
BR
EOW
Like I saw my simulation, the angular velocities must not be w, 2w and 4w but w, 2w and 6w. With 2 supports, the motor and the Support1 need -6FRwt, the Pulley2 recover 6FRwt. But with one support, the motor and the support need -6FRwt and the Pulley2 recover 6FRwt, but there is the torque on the support, that torque gives the energy 2FRwt. It's necessary to check the sliding of the belt with w (support),2w(Pulley1) and 6w (Pulley2), if the sliding is 0 this could say the case with one support must give an extra energy to the support.
EOW
For explain the forces F1 and F2 in my last example. Take another simple example, I renamed forces, with one pulley. Apply a force F1 to the rope, that force is transmitted to F2 along the rope. F2 want to move the pulley to the left, so F2 apply a force F3 to the axis, the fixed axis reply and give the force F4. F1/F4 is a torque that turn the pulley but the support receive the force F3. With 2 pulleys there are 2 forces, and if the size of the pulley is not the same there is a torque. Do you understand ?
EOW
I made a mistake with the force with one support. If I brake the Pulley2 on the support, you're right there is no torque (first image shows all forces, grey color -> to the pulley, magenta color -> to the support and black colo -> to the belt).
Now, second image, I don't brake the pulley2, imagine it with a mass. I accelerate more and more the Pulley2, the energy is in the kinetic energy in the pulley. The sum of forces are like I drawn, no ? And the support decelerate because it receive a counterclockwise torque from force F1 / F2, no ?
dieter
Hi EOW,
I would say yes, as long as the pulley is accellerating, the inertia of the mass will give an opposite torque to the support. I guess this happens due to an imbalance of centrifugal force on the pulley shaft. Not sure tho.
BR
