Sum of torque
Started by EOW, October 12, 2014, 05:36:02 AM
EOW
This case is better, I found the torque at 0.74 at top, 0.37 at the center and 0.26 from the torque of the blue wall. 0.74-0.34-0.26=0.11
EOW
I added all informations for verify my calculations, if someone has a little time to verify and tell me if it is correct ?
dieter
Sorry, I was offline for a while.
I had in mind to simulate magnets together with normal newtonian physics, but it turned out to be rather complicated, so I started programming a magnet simulation entirely in Blitz (without ODE).
It works, a bit too well tho: my permanent magnet motor works in almost every configuration :-) very much unlike in real live.
ODE has all kinds of links, also friction and things. I did some basic tests, like a curtain or chains, a rotor with hinge, stuff like that.
If one takes some time to get into ODE, I think such devices as you designed can be simulated quite effectively.
At least this is a package that works out of the box and you don't have to compile the ODE Api by your own.  (that is for "DC"'s api distro)
EOW
It could be useful to simulate.
I drawn the device in many positions. Note if I don't use the ground for the force F1, the sum of energy is always at 0. If I use the ground for F1, I can win an energy in a few positions like the first I drawn, the angle is pi/2 I think. In other cases when I can't win an energy, I don't use the ground for the force F1. I wait the next good position and I use the ground.
dieter
To me equations are the secret code of the academic class ... invented to disguise simple terms in a dense fog of mysterious haze and archaic greek letters . <:^)
Anyway, I made a package for ODE , see also PM.
