Quanta Magnetics Experimental Kits
Started by Scorch, October 15, 2014, 02:06:58 PM
ramset
nelsonrochaa
If you have a valid input measurement  and are running a halogen in DUT you can do some very simple tests to establish unusual behavior.
you will need a thermometer and a cardboard box [in addition to Meters for input]
Take your entire setup and place it in a cardboard box with a thermometer [EVERYTHING}
Note temp inside and outside the box ....
start device under test [DUT]
Monitor input power and note inside temperature ,when inside temp no longer rises [for a minute or so]
write down that temp ,this is your fixed loss to ambient temperature .
now repeat test ASAP with just the Halogen and the supply battery at same input power as previous test.[this is called control run]
if temp of DUT went higher than control run you have something to investigate.
running test simultaneous in same conditions [outside] would of course be my choice.
hope this is useful.
respectfully
Chet
Thanks Grandma
nelsonrochaa
Quote from: ramset on October 31, 2014, 03:02:05 PM
nelsonrochaa
respectfully
Chet
Hi Ramset ,
I appreciate your suggestion and i will try to reproduce that  test because seems interesting measure by this point of view. I can tell that their is not a particularly reason to use the halogen car lamp is only because this particularly lamp need several watts to glow and the voltage drop dramatically if is connected directly in to the battery source, is a way to show the output . In other example (https://www.youtube.com/watch?v=F7EkHm08Te4)i use a 4w 12v car in serie with battery to monitor de amp consumption in the circuit .You can see that lamp not glow ever when a load in the circuit output  a  55W 12v halogen lamp because the power dont come from the load .
thanks for the suggestion
nelsonrochaa
nelsonrochaa
respectfully
Chet
Hi Ramset , i try to make a shots with my new scope. https://www.youtube.com/watch?v=SALlSg972y8
Its the possible for now.
Thanks
Arman
Hi nelsonrochaa,
you haven't shown energy input and energy output. What you have showed that you connect first your circuit to power source and then it accumulates some energy and then you connect the lamp, however you are not showing continues connection of load, and monitoring in power and out power for long period of time. The accurate measurement should take in account the energy in and energy out, where energy= Power * time.
Best Regards
Arman
nelsonrochaa
Quote from: Arman on November 18, 2014, 07:09:31 AM
Hi nelsonrochaa,
Best Regards
Arman
Hi Arman  thanks for your post,
The video that you talk is about recuperation and you have true  about the stored power in the cap and that is the point. How much time and current in the source   you need to storage in caps enough to power   55W halogen bulb with so low power current in source  ? think in that and you will see that i have right .You can see the drop near to zero in the voltage when i connect the lamp direct in the panel.
But you can see in this video to see how the power can be continuous in the output .
I dont have much resources to make measures like i want , and all people want. But you can test , will not be expensive ! WY you don't try make to see by your eyes ?
Thanks Arman and good luck
https://www.youtube.com/watch?v=pf_qUlwSZl0
https://www.youtube.com/watch?v=9daYU4JBMu4
https://www.youtube.com/watch?v=YegRP2521jI
I don't have the needed tools
