Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
tgraca
Quote from: tgraca on November 28, 2014, 01:47:33 PM
Today - 1080 mV under load.
Today - 1083 mV under load. - having connection issues with the cathode - copper taped onto mag strips.... may have to remove copper and solder alligator clip to JT to attach to mag. from now on.
tgraca
Quote from: tgraca on November 28, 2014, 01:56:18 PM
Today's mV reading under load - still 731
Today's mV reading under load - 715
tgraca
Quote from: tgraca on November 28, 2014, 01:43:49 PM
Today - 1054 mV under load.
Today - 1084 mV under load. I think yesterday's reading is an ongoing issue with my technique of taping the cathode connection - copper taped onto the mag strip.
tgraca
#344 was holding 632 mV under load and barely lighting the LED with the JT circuit. I checked the amp draw, which was 215 uA. I disconnected the JT and recharged it directly from the alum battery, which was at 9.36 volts and probably pushing lots of power... about 20 seconds. When I checked it again, it was showing 430 mV under load and no light. I checked the amp draw on the circuit and it was bouncing around from 36 uA to 280 uA... something very wrong now with this cell... I watered it and repeated the test... I got a little more power, but it quickly died again and was showing about the same results... it won't take a charge like this... The 345 alum rebuild seems to be working fine, so I may do that to this cell...
tgraca
showing 724 mV under load. Draw was 0.84 mA for the JT circuit. Disconnected JT and and got 1.67 V... shorted it and got over 6 mV initially then it did a slow drop starting around 5.56 mA... It's still a little wet from watering yesterday, but mostly dry... waited a couple minutes and reconnected the JT circuit with similar readings... 725 mV under load w/draw of 0.85 mA... wet the cell and after a couple minutes, it was pushing 935 mV with a draw of over 3 mA.... but dropping quickly... after 16 minutes, it seems to be holding around 1.15 mA and 754 mV
