Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
0 Members and 18 Guests are viewing this topic.
tgraca
Quote from: plengo on November 30, 2014, 01:43:47 PM
if you could build a 344 with the paper I mention but FC62 (the charge), would be wonderful. I want to see if your process build will be similar to the results
I posted my next build plans earlier. There are differences including use of a borax/water rinse on the mag strips and coffee filter cover. I will build 2 at the same time - one with a charge of about 30 seconds - one with a charge of about a 1 second - just a tap. I am working on some wooden shelves for single cells and circuits at the moment. I built 2 shelves this morning, but if they work out, I will build several more shelves and just hang them around the house as I build these things. I like these as little nightlights! I don't have to turn the main room lights on when I wander around in the middle of the night!! Ill post a video these stands and builds when I am done.
In the meantime, have you made any progress on your formula? I think the one I used for 344-345 is over a year old. When I get the shelf thing down, I am probably going to build 8-10 of these all at once just to see how long it takes.
plengo
Quote from: tgraca on November 30, 2014, 01:59:55 PM
Great man, great work.
This formula IS old but it is very important and it is working very well. Don't worry about more of my formulas since this one is ONE i think can be used and replicated by others easily.
I have been testing extensively with the Mg strips again more in line with what you've done so that I also have a baseline based on your tests.
I am also replicating extensively the "super 149" so that ANYONE can replicate and have a very lasting cell. How long it will last??? I have no idea, but it will for a very long time. Specially if adding a drop of water every month. I am NOT ADDING water but I can see if she dies water will also work in very small quantities.
Fausto.
plengo
I have a very important question that an engineer could answer please:
- Can we have a circuit with very high resistance and very high conductivity?
- Can we have a circuit with very low resistance and low conductivity?
I know that V = I x R and if resistance goes higher so it will voltage BUT if conductivity is high, which is current very high, than voltage should be even higher. Now, if Resistance is very high and voltage is very high also, current tend to be small.
I also know that one variable changing will by consequence change the other variables. So it would not be possible to have high resistance and high current, they are reciprocals of each other, right?
Increasing Voltage increases current. Increasing Resistance decreases current. Increasing current decreases voltage.
So there is the paradox for my 2 questions above.
Fausto.
tgraca
I have had 345 hooked up to my 3F JT circuit all day and the extra 3F cap seems to bounce the charge around... It was showing 765 mV under load. I just disconnected it and checked the mA reading and it showed 73+ mA and it held there... the voltage climbed very slowly to 1454 after about 7 minutes. It's basically an alum cell now, but it has some interesting properties like taking a charge. We'll see how long it works without watering.
Heavens Pavement
Here are 3 cells using f133(not 134 on pic).
2 strips of magnesium per cell
The paper towel separater has the formula pasted on and allowed to dry then wrapped around the magnesium.
i usually only have 1 to 2 layers, but watching one of Fausto vids said something about more hotdog like ;)
these are wrapped 5 around.
2 cell read 300 ish millivolts /.2 micro amps
the other reads
40 milli volts/.2 micro amps, then when i switch over to volts it reads over 100 millivolts and starts dropping....strange..
These have been resting about 5 days since the "Fausto Sizzle",but i can only so 30 Volts DC...
I will be making more but I have Questions at this point....
1 Is the "Fausto Sizzle" at 30volts DC Work? what water to Epsom mix for this part?
2 Wraps of paper towel/with mix  around magnesium recommendation
3 recommendation to activate.. once again Epsom to water ratio.
Thanks..
[pics reduced by admin]
