Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
Heavens Pavement
Yikes sorry about the huge pics they where so small when editing...
I now have Super Fausto 134 on sheets drying..
When giving f133 the f30v treatment a almost olive green came oozing out by the Magnesium, the pic doesnt show this :(
Anyone else see this?
tgraca
These are holding up...
#354 is at 1065 mV under load
#355 is at 782 mV under load. This one was unsealed, so it is drying out.
- Opened it up and watered it, then resealed it. It's at 982 mV under load.
tgraca
Quote from: tgraca on November 30, 2014, 01:22:45 PM
converted to an alum water-as-fuel cell.
BackRoom Labs on YouTube had me check the alum I was using in the corrosion test. It turns out I accidentally bought the wrong type of alum.
I used the ammonium type. They were out of McCormick on the spice shelf and I bought Sauter's brand instead, which is clearly marked
ammonium alum... oops! lol - I bet the 4 feet of mag strips in cell #345 will be liquid by the end of the week! lol
I plan to build more cells and give them a ZAP today. I'll post something when that is done.
tgraca
#352 is 1014 mV under load. Built Nov. 23, 2014
#353 is at 1050 mV under load. Built Nov. 25, 2014
plengo
40 milli volts/.2 micro amps, then when i switch over to volts it reads over 100 millivolts and starts dropping....strange..These have been resting about 5 days since the "Fausto Sizzle",but i can only so 30 Volts DC...I will be making more but I have Questions at this point....1 Is the "Fausto Sizzle" at 30volts DC Work? what water to Epsom mix for this part?2 Wraps of paper towel/with mix  around magnesium recommendation3 recommendation to activate.. once again Epsom to water ratio.Thanks...
The reason for the change in voltage when you change the volt meter is that different scales has different impedance mode and therefore the cell adjust itself to that load. Those are CURRENT SOURCE cells not voltage source. They are VERY sensitive to the load and tend to minimize the output power given for that particular load up to a level where it finds the "middle point".
answers:
1 - 30 Volts will be OK
2 - You said about 5. By the picture I would triple it.
3 - All Epson solutions are 3 1/8 tsp for 50 ml distilled water.
Concerning the "super fausto", oh my goodness ( ;D   ) change it to "looser fausto".
Btw, welcome.
Fausto.
