Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
plengo
Quote from: tgraca on December 08, 2014, 09:56:10 PM
Mine are rated at 3000 mA/hours... thanks for the correction! That makes me feel a little better about my efforts....
Did you see my video about the crystal cell/JT generating over 40 volts? I am studying the Patrick Kelly documentation
(again) on how to use this to charge batteries... fun!
Yes I saw it, it is impressive. What is that oscilloscope you have? I will try to build a JT like that. I ordered the inductors from China.
Fausto.
tgraca
Quote from: plengo on December 09, 2014, 11:06:15 AM
Yes I saw it, it is impressive. What is that oscilloscope you have? I will try to build a JT like that. I ordered the inductors from China. - Fausto.
The oscilloscope is a DSO Nano V3 (version 3)... I think I got it for around $70 on eBay delivered earlier this year.
It works well, but I haven't figured out how to get a frequency reading... I have to use a calculator to translate uS into kHz.
I had never tested these JT's without a load before and was surprised at how they work without a load. This explains all
of the JT transformer and battery charging effects I have been seeing for the last year. It's a much better way to tune a JT
than the one I have been using... way better...
I am doing my final testing today on the inductor values. When I find what I like, I will start winding them with this 3200'
of 30 AWG that has been calling my name for the last 3 weeks! lol - I think a custom wound bifiler and transistor will end
up costing me less than $0.25 each, which is less than my old JT designs with caps and resistors. Too bad too... I just got
100 caps in yesterday - 100 uF's, 25V - nice and small!
I may experiment with the Tesla Switch idea using caps instead of batteries. That would be really interesting... I have seen
someone doing this as "electrets" but I don't think he was calling it a Tesla Switch...
plengo
Status.
Cell 149 (the one in the graphs) is finally showing signs of decay of power. Since November 16 to today she lost about .001 volt under load with a few drops of Epson solution only. I have not added water since November 10.
The metals inside look just like before and no visible deterioration is present but I have not dissected the cell.
I assume the loss in power having to do with water evaporation since this cell is not sealed. The major reason I started to seal those cells in epoxy resin.
Under short she was showing around 2 mA. Under load on a Green 10 mm LED is showing 2.58v.
I think this cell is the most successful cell of mine to date. A flat graph with only a very small loss of power. I will let her run for longer and later add 1 drop of water to each of its 3 unit cells and graph it again. Very boring work.
Fausto.
tgraca
Quote from: plengo on December 09, 2014, 11:39:29 AM
Status. Cell 149 (the one in the graphs) is finally showing signs of decay of power. Since November 16 to today she lost about .001 volt under load with a few drops of Epson solution only. I have not added water since November 10.
I assume the loss in power having to do with water evaporation since this cell is not sealed. The major reason I started to seal those cells in epoxy resin. Under short she was showing around 2 mA. Under load on a Green 10 mm LED is showing 2.58v.
Fausto.
Nice work. re: "Very boring work."
When you get your JT's in order, I hope you consider testing multiple single cells with various configurations. I know you
don't have enough computers to make those graphs for a bunch of cells, but you can just take a cue visually daily of each,
and start taking reading when they are looking low... the way I do it... I am planning on having 20 good cells running by
the end of this month... I can't imagine using 20 computers to manage this.... and taking visual cues and eventually taking
readings takes almost no time. It's not boring at all! ;) -- Plus... now I can roam throughout my home in the middle of
the night without turning to turn on lights... I used to bump into things rather than turn on a light... I have chickens out
side, and when they see the lights come on at 2am, they start crowing! lol
tgraca
Quote from: tgraca on November 23, 2014, 04:18:08 PM
https://www.youtube.com/watch?v=4MubBsGGtxk
This may be the new winner. I made a graph for you. The major difference in the electrolyte is that I coated the mag strips
with some watered down silicone (latex) caulk and MnO2/Activated Carbon first, there is no hydrate #5, and except for
watering the coffee filter around the mag strips, the electrolyte ingrediants were pinched in dry.
717 mV under load after 18 days.
