Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
NickZ
   NO electrlyte. Just air and sealed on top. The cells can be placed in series, for higher voltage.
Carbon does not oxidize, like metal does. Aluminum is cheap, or free.
skywatcher
Quote from: NickZ on November 13, 2019, 06:16:20 PM
So you took an aluminium can, filled it with aquarium coal (that's also called 'activated coal' ?), then stuck a carbon rod into it, and that's all ?
No other materials (except of the epoxy for sealing) ?
https://en.wikipedia.org/wiki/Aluminium%E2%80%93air_battery
But an aluminium-air battery also uses electrolyte... so it's also a 100% galvanic cell.
BTW the aluminium is not free because the energy you get from it is the energy which has been used to produce the aluminium.
It's the reversal of the same chemical reaction.
NickZ
   Of course you can use an electrolyte, for higher output, as well as a higher break down of the aluminum/Mg used.   Aluminum was or at least has been free, for me. Activated carbon can be at bit expensive, but worth using.   It was all fun, at one time...
sm0ky2
Using like electrodes is one way to eliminate galvanic deterioration
This does not prevent oxidation in certain metals, and thus is not always the answer.
If the energy is coming from an outside source, due to physical properties
or is stored in the electrolyte itself,
Inert electrodes, (such as carbon rods used in the center of lead-acid batteries) are
the certain method to eliminate galvanic reactions as the source of potential.
outside radiation is almost inherently absorbed by spacing, or thickness of the layers.
as a multiple, equivalent, or fraction of specific wavelength(s).
in this manner, energy can enter into the cell and appear as potential on the terminals.
One such example is a non-polarized electrolytic capacitor
many of these are sized to available environmental radiation
and will "self charge" when placed across a high impedance
some electrolytes catalyze when a circuit is closed between the terminals.
These batteries are generally "chargeable".
Supplying an electric potential across the terminals will reverse the reaction.
These electrolytes are combination solutions. Containing multiple chemicals, or at least one
compound that releases energy when it breaks down and absorbs energy to facilitate recombination.
Molecular and ionic fuel cells operate by this principal.
There are other ways energy can enter into the cell, as well.
The first step is to eliminate electrode degradation.
