GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
Haven't we had this discussion before?
http://en.wikipedia.org/wiki/Patent_pending
I don't know about Canada, but in the USA and in Australia, it is actually illegal to use the term "Patent pending" in sales or descriptive literature about a product unless a patent application has actually been filed.
QuoteFraudulent use of a patent pending designation is prohibited by the law of many countries and inventors should be cautious when marking products or methods that may arguably not be covered by any pending patent application. In some jurisdictions, such as the United Kingdom, a warning notice should ideally mention the number of the pending application.
In the USA:
QuoteThe use of the term "patent pending" or "patent applied for" is permitted so long as a patent application has actually been filed. If these terms are used when no patent application has been filed it is deemed as a deceptive act and a fine of up to $500 may be imposed for every such offense.
The Canadian patent article is longer:
http://en.wikipedia.org/wiki/Canadian_patent_law
And from what that article contains, I am wondering how a box full of commercial off the shelf items connected in obvious and well known ways could ever be considered patentable. Especially after the video and other "disclosures" from GDS.
So what are the numbers of the Canadian patent applications, then?
Quote from: MarkE on October 27, 2014, 10:12:07 AM
Gotoluc allow scripts.
It gets funnier.  Here is the product detail information from alibaba  http://m.alibaba.com/product/50002273662/Portable_water_generator_runs_on_water_/productdetail.html
Portable water generator (runs on water)
Quick Details
Place of Origin:    Ontario Canada
Brand Name:    GDS
Model Number:    GDS5000
Type:    Generator
Electricity Generator Type:    runs on water
Output Voltage (V):    110
GDS5000:    5360
Packaging & Delivery
Packaging Detail:    Foam with Cardboard
Delivery Detail:    31 Days
Specifications
Portable water generator that runs on water,copper coils and magnets.creates 5000 watts of electricity per hour.
GDS5000 which produces 5000 watts of power for light duty. Use for your house, cottage or small construction project. Emergency back-up power, concerts, camping, motor home. This unit is also 50% less noisey than traditional generator so you can use indoors with NO Fumes and NO Pollution and it's a great way of saving energy cost and helping the environment.
How does it work?
When you receive your new portable water generator just add 4 gallons of normal water in the tank and turn the red toggle switch to on position (emergency safety) that will start the battery and pump and turbine all at once, it's that easy. All units have been tested before leaving our facility.
Instruction and warranty manuals will be supplied with every unit sold.
How do I know which unit I need?
Simple, on ever electrical product that is made, there is a sticker and it will show how many watts per hour it uses then total all the watts together, that will tell you how many watts you are using and will help you decide which unit best works for your needs.
SPECIFICATIONS
Product Series GDS5000
AC Voltage 110/240
AC Frequency 50/60 hz
Energy Type Turbine Generator 5kw
Generator Coils and Magnets
Start method Battery
Ground On Frame
Water Gauge On Tank
Digital Hour meter with volt/amp meter
Start Switch Type On/Off
Handle Style Single Folding/Locking
1 1⁄4 Steel Frame Strength and Durability
Emergency Stop Button Yes
Well well well. It appears that Gregory Potter has been trying to reduce his exposure on AliBaba. Try that link now....
And this page has changed too:
http://www.alibaba.com/product-detail/Portable-water-generator-runs-on-water-_50002273662.html
And of course a search of the Canadian patent database returns no results for Gregory Potter. That could be because his application is too new to appear there, of course.
profitis
So we can deduce that after seeing your cries of scam etc here that the inventor is still determined to inject onto market mr tinselkoala.this is a good sign.
profitis
Please note that the claim is NOT a claim of overunity of any kind.
MarkE
Quote from: profitis on October 28, 2014, 04:11:52 AM
Please note that the claim is one of powering an engine from water.  You are welcome to explain how hundreds of MJ may be obtained from 16 liters of tap water.  Perhaps you would like to post a demonstration.  You do claim expertise in chemistry don't you?
