GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
e2matrix
You would think there would need to be some sort of piston based engine (like a converted gas engine) for this to run off water.   It doesn't look doable with what is seen in the pics tinman posted.    This is also looking familiar to something that came up before where it turned out the pictures of the generators were just photoshopped pics from a gas based Chinese engine - pics even matched the China warehouse.  That sound familiar to anyone?
MarkE
Water goes into a tank.
The water supposedly fuels an engine.
What does the water supposedly turn into as it gives up energy to run the engine?
The water tank has no visible connection to anything else in the box.
The box contains ordinary 12V batteries and two off the shelf inverters one of which is clearly wired directly to one of the batteries.
The box has at least one motor that spins.
The box is advertised as containing:
5kw/10kW/15kW Turbine Generator
AC Voltage - 110/240
Digital Hour Meter
ON / OFF Switch
They do not say that the box has any current or voltage or power indication.
They say silly things like:  "3000 Watts per hour".
Or that a 3000W unit cannot run a single air conditioner, but that a 5000W unit (1.67X capacity) can run three air conditioners.
They do not state consumption rate of the water "fuel".
How much more does anyone need to know about this to know the claims are BS?
ramset
Perhaps send out a call to Canadians who are close to Toronto before you light the torches
Mark E.
Maybe summon Captain Zero....[I believe he is close to Toronto]
A 10,000 rpm "Turbine" was mentioned ,it runs 4 days on 4 gallons of water,  the unit in the Vid does not look like anybody is cutting and pasting anything ?
Also They don't seem timid about showing the inside works ?
Chet
Thanks Grandma
gotoluc
I would volunteer to go test the unit with my portable 1500 watt heater... but since I'm in Ottawa which is a 4 and half hour drive each way to Toronto and also leaving the country on Saturday November 1st I don't think I'll have time.
Lets see what they say when called on Monday
Luc
profitis
Probably some sort electric-to- electrolysis-to-electric conversion efficiency thing going on here.
