GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
MarkE
Quote from: ramset on October 26, 2014, 12:45:16 PM
Perhaps send out a call to Canadians who are close to Toronto before you light the torches
Mark E.
Maybe summon Captain Zero....[I believe he is close to Toronto]
A 10,000 rpm "Turbine" was mentioned ,it runs 4 days on 4 gallons of water,  the unit in the Vid does not look like anybody is cutting and pasting anything ?
Also They don't seem timid about showing the inside works ?
Chet
A bald faced liar is still a liar.  Again:  The machine contains no visible connection between the water tank and the internal workings but a direct connection between the lead acid batteries and the inverter.
tinman
Quote from: MarkE on October 26, 2014, 08:04:33 PM
It would seem that it may be a 3 phase pelton generator that is mounted to the side of the tank.There also seems to be a pump mounted in front of the motor thats driving who knows what.
These images compliments of Groundloop from OUR.
tinman
We also get a quick glimp's of what may be the pelton wheel in the water tank.
Surely this setup didnt have any merrit :o
https://www.youtube.com/watch?v=LckOcHJ7r8Y
gotoluc
Thank you Groundloop for the excellent detective work ;)
Luc
gotoluc
Here is the link to buy the Pelton Generator for $211. on ebay
http://www.ebay.com/itm/Micro-Home-Power-Water-PMA-Generator-and-Pelton-Wheel-1000-3000-Watts-12-36-VDC-/191154591960
My guess is the 2000w inverter is powering the dark grey AC motor which is attached by v-belt / pulley to the silver permanent magnet generator
which is worth about $460. on ebay
http://www.ebay.com/itm/Freedom-II-PMG-12-24-volt-permanent-magnet-alternator-generator-4-wind-turbine-/291164191208?
My next guess is the other long silver 3000 watt inverter powers the AC output receptacles and maybe other single black AC motor which is possibly an off the shelf stripped AC pressure washer pump to spin the Pelton Generator at high speed.
Here are the batteries Pdf Datasheet
http://www.trojanbattery.com/pdf/datasheets/31GEL_Trojan_Data_Sheets.pdf
Luc
