GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
ramset
fellahs
I am interested in nothing but the test.
You fellahs do what you do .
apologies
Chet
Thanks Grandma
MarkE
Quote from: ramset on November 07, 2014, 09:04:27 AM
fellahs
apologies
Chet
What equipement do you have available for the test?
FatBird
@  ariovado
Any new info ariovaldo??
ariovaldo
Quote from: FatBird on November 07, 2014, 01:31:16 PM
@  ariovado
I have everything ready but the time to test. I will try to do a simple test by Monday. I'll let you know..
Nink
What are the expected outcomes of the test? Will the results be made public? Will the inventor be permitted to point back to the test results? Will overunity, its members, testers or others be liable if the results are incorrect?  What protection will be provided for consumers in the event the results are perceived by the general public as an endorsement of the authenticity of the device? What exactly are you testing? Is this just energy output or are you also testing against any possible attempts on the part of the inventor to influence the results? Will you be testing the fuel source for chemicals or other additives or will you be providing your own pure water? Will you be permitted to test the water for chemicals during the electricity generation (tap and monitor water transformation process if any) or is this a non invasive test?Will you be testing the vapour exiting the unit? Will you be testing for other potential fuel sources that may be external to the device? Microwave, laser, induction, or conduction into the device? Will you be checking other potential internal fuel sources such as monitoring for radioactive material, high density or next gen battery systems, chemical reactions or other potential fuel sources? Will you be testing and checking external environmental factors or will you be relocating this "portable generator" to another location to remove any possible opportunities for the results to be invalid. Will this be a single test or multiple tests? What unit will you be testing? How long will each test last? What are the skill and qualifications of the people providing the tests? Will the inventor be present in the tests? What components will be deemed MO and not subject for inspection versus non MO components? Will the battery power source be disabled during test? ........
These are all of course fairly obvious questions and certainly should not be considered an exhaustive  list of questions for testing consideration. My primary concern is something is missed and perceived commitments or endorsements are made on behalf of the team performing the tests,  and the capabilities of this invention are later proven incorrect.
