GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
MarkE
Gotoluc allow scripts.
It gets funnier.  Here is the product detail information from alibaba  http://m.alibaba.com/product/50002273662/Portable_water_generator_runs_on_water_/productdetail.html
Portable water generator (runs on water)
Quick Details
Place of Origin:    Ontario Canada
Brand Name:    GDS
Model Number:    GDS5000
Type:    Generator
Electricity Generator Type:    runs on water
Output Voltage (V):    110
GDS5000:    5360
Packaging & Delivery
Packaging Detail:    Foam with Cardboard
Delivery Detail:    31 Days
Specifications
Portable water generator that runs on water,copper coils and magnets.creates 5000 watts of electricity per hour.
GDS5000 which produces 5000 watts of power for light duty. Use for your house, cottage or small construction project. Emergency back-up power, concerts, camping, motor home. This unit is also 50% less noisey than traditional generator so you can use indoors with NO Fumes and NO Pollution and it's a great way of saving energy cost and helping the environment.
How does it work?
When you receive your new portable water generator just add 4 gallons of normal water in the tank and turn the red toggle switch to on position (emergency safety) that will start the battery and pump and turbine all at once, it's that easy. All units have been tested before leaving our facility.
Instruction and warranty manuals will be supplied with every unit sold.
How do I know which unit I need?
Simple, on ever electrical product that is made, there is a sticker and it will show how many watts per hour it uses then total all the watts together, that will tell you how many watts you are using and will help you decide which unit best works for your needs.
SPECIFICATIONS
Product Series GDS5000
AC Voltage 110/240
AC Frequency 50/60 hz
Energy Type Turbine Generator 5kw
Generator Coils and Magnets
Start method Battery
Ground On Frame
Water Gauge On Tank
Digital Hour meter with volt/amp meter
Start Switch Type On/Off
Handle Style Single Folding/Locking
1 1⁄4 Steel Frame Strength and Durability
Emergency Stop Button Yes
Quote from: gotoluc on October 27, 2014, 10:11:07 AM
See attached screen shot I get when I click the link in my browser
Weird. But you can see that your browser isn't loading the right link, in the location bar.
Maybe your ISP is protecting you from clearly fraudulent advertisements.
gotoluc
Quote from: TinselKoala on October 27, 2014, 10:15:08 AM
Yes, that's right
Here is the correct link: http://www.alibaba.com/product-detail/Portable-water-generator-runs-on-water-_50002273662.html
EDIT, no it still redirects!... must be my browser script thing?
