GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
mscoffman
Thanks for people pointing things out in the pictures. I wouldn't worry about fit and finish problems
because these seems are prototypes.
It does looks as though this may be several different OU ideas implemented at the same time. One thing
I had thought about is perhaps he is direct heating the water in the tank then steam+HHO would come out
the hole in the tank above the Fan, a jet nozzle on a stopper might fill the hole and point towards the 'fan' now
turbine. I can't see why a pump Pelton wheel pump combo would leak that much water over that short of time.
Also the tank rinsing instruction wouldn't make sense.  Sometimes thieves do not understand the technology
sufficiently so they use the first working structure they come upon. They can't optimize results sufficiently.
It looks to me like this is a *Qmogen* operating on hardware meant to be a wind (small scale hydro)
energy set up. So this appears to be a dual coil PMA permanent magnet alternator with a dump load
battery controller with its large power dissipation resistors. If he has done it this way that is
pretty good actually, in that the unit will have stable electrical load dynamics characteristics
of standalone a wind generator energy system. The brush type DC electrical motor can follow the
external l electrical load at it's leisure.
As someone already mention;
I see *no* HHO electrolyzer, gas washer, electrolyte controller, flashback suppressor.
I see *no* combustion engine and no combustion heat path.
You know, This might not be too hard to do.
Use an existing generator support stand I'll bet he got his tank as a diesel fueled
generator fuel tank. And a small scale standalone wind generator dual core PMA
Alternator setup.
Added: Water heated by cavitation?!?
Actually him taking down advertisements is *highly* negative.
:S:MarkSCoffman
polln8r
I can't see where they actually claim any OU or even mention anything about efficiency at all. They leave an appallingly large amount of info out of their presentation, but the little bits that they do mention are technically all true, no?
MarkE
No the technical claims they make are not all true.
Their device is not powered by water.  It is powered by the stored energy in the batteries.
It is a clumsily assembled battery in a box scam.
e2matrix
Yep, gotta agree with the naysayers on this one.   SCAM.   I can't see any way this can produce the power claimed continuously on a little bit of water.   I saw the guy said he got 10 orders already.   So if they paid with PayPal (they have a PayPal button on the gensets) and he's got $50,000 or so in the PayPal account that would be a nice haul if he is able to transfer it to his bank and then close his account.   Fortunately PayPal won't normally allow sudden large inflows of money to be taken out of the PayPal account.   But consider they state something like 32 day delivery time .... I see a possibility this could leave a big hole in 10 wallets.
hawkiye
Quote from: TinselKoala on October 27, 2014, 09:29:08 AM
The Pelton-wheel generator inside the tank can't do anything unless there is _water flowing_, turning the Pelton wheel. This is obvious, isn't it? So where does the water flow come from to turn the Pelton wheel?  The rest of the thing might actually work, as long as a strong water flow is driving the Pelton-wheel generator. Without something turning the generator though... then what?
Patent numbers, please.
I don't know if this answers that question to any degree but thought Id post it anyway...  from their FAQ: http://www.gdstechnologies.ca/FAQ.html I THOUGHT YOU NEED A RUNNING STREAM OR A POND OR RIVER TO CREATE THIS AMOUNT OF ENERGY?[/color][/font]
Yes you are correct however with the setup of many coils and magnets make up for the amount of energy required for each application.
