Thanks to ALL for your help!!
SSG modes COP
Started by nilrehob, November 04, 2014, 03:54:31 AM
Dave45
Quote from: TinselKoala on November 04, 2014, 10:04:38 PM
The triggered pulses are pretty short, 25 ms or so.
The circuit in action:
http://www.youtube.com/watch?v=0dMPQs5vpek
Too Cool
Bro I have to say you do good work.
nilrehob
Quote from: TinselKoala on November 04, 2014, 07:14:11 PM
I wonder what "COP" you get in MHOP mode.
Isn't MHOP about how to trigger the switch rather than where the switch (and the rest) is in the circuit?
/Hob
Quote from: nilrehob on November 05, 2014, 01:34:42 AM
/Hob
That's mostly true, although there is a little finesse in the output side as well. But yes, it is still your basic lowside switch arrangement.
The MHOP's sense/trigger system gives the operator full control over dwell and timing, and the optional strobe circuit lets the user know the timing and dwell without the use of external instruments like a scope. The coil polarity can be reversed by a switch, so it's easy to change from an attraction-type to a repulsion-type PM without complicated reconfiguring, and the power take-off and recirculation bits have options too. The recirculation, for example, uses 2 neons, one each to the positive and negative poles of the run battery.
Quote from: Dave45 on November 04, 2014, 11:04:00 PM
Too Cool
Thanks! I'm learning, right along with the rest of us.
PhiChaser
Trying out a variant, seemed like a fun thing to try and make, thanks for sharing TK!
Pic of my (second) attempt; used an LED instead of the diode and I added a 331 potentiometer on the positive input instead of a 330 ohm resistor.
Okay, back to lurking... ;)
Phi Chaser
