Thanks to ALL for your help!!
Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
What are the possibilities of experimental errors in the vertical tube Magnet Repulsion Experiment?
Prof. Dennis Leung is correct in breaking the lead-out energy flying saucer into many small student projects.  The first one he chooses is the vertical tube Magnet Repulsion Experiment.
As Physicists and Engineers, we all did the experiment with a coil and a magnet.  The most common experiment is to pass DC current through the coil to turn it into an electromagnet.  This electromagnet is then used to interact with a permanent magnet.  The attraction and repulsion behavior can be easily demonstrated.  More advanced experiments include comparing air core with ferrite cores.
The suggested experiment is to accurately measure the Electrical Energy Input with the Potential Energy Output.  All Universities and Commercial organization with good DSOs can do the experiment.
The plan is for the preparation team to do a sample experiment demonstrating overunity.  This will be confirmed and verified by hundreds of Undergraduate and Post graduate Students at Hong Kong University.  The Students will compete to modify the demonstration set up to get the best COP.  This is expected to be followed by other Universities in Hong Kong and Worldwide.  The scientific data and paper will then be published officially.
The chance of an experimental error by hundreds or thousands competing Students and Universities is next to zero.
China and USA may have no choice but to disclose their top secrets.  The many reported UFOs may already be using the lead-out energy flying saucer technology.  The 225 HP Pulse Motor and the Tsinghua University Energy Multiplier may see daylight.  The World will benefit.
I shall post my efforts including every material purchase, every experiment detail here.  I may make mistakes.  My poor eyesight and shaky hands are prone to errors.  Do not rely on my results.  Rely on the hundreds of improved competition experiments and the Official Scientific Papers from Hong Kong University and other establishments.
Divine Wine flows.
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg50206#new
ltseung888
Material list for the draft experiment on Vertical tube magnet repulsion.
1.   Vertical transparent tube 30mm inside diameter, 1 meter, HK$65, Sun International Supplies Limited 2780-0858
2.   Round circular magnet with hole in middle diameter 28mm, Six at HK$18 each, Wah Fai 9753-3792
3.   One coil wire 1mm diameter, 100 meters, HK$80, Wing Hong Electrical Supplier 2625-4736
4.   One ohm resistor up to 10 watts, Two at HK$6 each, Crocodile Clips etc. at HK$18, Bozam Radio Service 2388-9859
5.   On and off switch up to 10 Amp, HK$31, Ban Wah Control Equipment Co. Ltd. 2770-0800
6.   10 meters Magnet Wire, 2 soft ferrite rods 10 cm long, one diameter 30mm, one diameter 35mm, HK$100 Wai Choi 2388-3839
An Atten Oscilloscope and a DC Power Supply up to 30V were available from previous purchases.  Estimated cost HK$3,000.
Total cost = HK$3414
The cost including travel, small tools etc. should be less than HK$3,500.
***This vertical tube magnet repulsion experiment can be done by almost every University, every Secondary School with a DSO in Hong Kong and Worldwide.  At this stage, it can be treated as a scientific experiment worth exploring.
Can USA and China stop such an experiment Worldwide?  Will they disclose their top secret to benefit the World?
Lawrence
joel321
I like the motto "give a man a fish and he will eat for a day, teach a man to fish and he will eat for the rest of his life"... sir you are doing a big movement! Which I see a small guy fishing in a big pond full of fisher men.
I use to fish myself as creativity. You can sense the bite of a fish with your six senses via just the sensory of the fingers. One can catch any fish with out looking at it. The more you catch, the greater the hook engineering improves. But it comes to a point where the energy of trowing in the hook is very little of what bites. COP >  blue whale.
Sir you motivate people and I'm glad there are people in this world like yourself.  GOOOD job sir! Looking at things from different angles comes with age and experience. My respects. I some times need a reminder that there is actual life outside my closet of enslaved fear to not get penalties with money when I speak out.
Lets educate the children with positive things instead if allowing them to watch spongebob.
BTW sir, interesting fact, piranha can bite through steel wire. Their teeth are like steel pliers. And their "mother nature" engineering teeth will amaze you. They are teeth like in a human mouth but they sharpen themselves when biting. It's amazing to understand these things. I believe that 99% of the modern population is "tapping" in to mother nature way of life. NO HUMAN HAS INVENTED ANYTHING ONLY WILL DISCOVER FROM THE GIFT OF MOTHER NATURE "FREEE" ENERGY" :)
ltseung888
Lessons learned from the first experiment.
1.  The 28mm diameter  magnet was too thin.  As soon as current was ON, it flipped and attraction took place.  One way is to use thick magnets.  Another way is to use multiple magnets to increase thickness.  Another way is to screw the magnet onto a wood or plastic piece to prevent flipping.  The non-magnetic HK$1 coin happens to have almost same diameter as the magnet.  Tried to tape 4 coils to magnet and got better results - no flipping.  May glue them together.
2.  The magnets are too strong compared with the coils.  The 1mm general purpose wire could not produce enough magnetism to attract paper clips with air core.  It could do so with the ferrite core.  When the magnet wire was used, it could attract paper clips even with air core.
3.  We may need to use more turns with the magnet wire.  Closer matching would be needed.  The present set up used 120 turns.  500 or more turns will be tried.
ltseung888
Pictures of various tests.
The first test is to check the properties of the circular magnet and the ferrite rods.
The circular magnets are very strong.  When two are attracted on top of each other, the only way to separate is to slide with great strength.
The Ferrite rod has no magnetism but can be magnetized easily.  It retains some magnetism for a short period after the permanent magnet is removed.  It does enhance the magnetism of the coil.
Following the Divine Guidance.
Lawrence
