Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
There are good pulses and bad pulses.
It is easy to demonstrate with the Fung Wheel.  If pressed too early, the repulsion will slow down the rotation.  If too late, little energy is given.  The surprising thing is that - some pulses showed negative voltage at both leading and trailing edges.
Without the DSO, how can a researcher be confident that he has generated the best pulses.
ltseung888
The same waveforms as reply 530 but with color inverted.
ltseung888
ltseung888
Quote from: ltseung888 on June 05, 2016, 08:57:55 PM
http://overunity.com/16645/reviewing-pulse-motor-circuit-ideas-and-theory/msg485820/#msg485820
The above thread is worth reading.
At the Upcycling Center in Wan Chai, there will be a sign:
Win a Prize
Pulse Rotate the Fung Wheel 10 times
Capture the Negative Voltage Waveform
Lead-out Energy to benefit the World!
*** Any one who can achieve that can win a small prize (one a day)
The best will have his/her picture displayed with the Waveform.
Anyone who can beat the best will be the new Champion.
The final Champion (in a Show) will get cash prize not less than HK$10,000
ltseung888
One senior citizen asked: "Can you build a flying saucer at the Upcycling Center?"
The goal is to share knowledge.  There is no point in bringing the knowledge into the grave...
