Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
Input power supply set at 5 volts.
The pulsed negative voltage reached  -580 V.
We shall try to get the best results. Bill Fung is back at US.  Actual development work on the Fung Wheel is likely to be suspended.
*** Negative energy or Lead-out energy at the leading edge cannot be ignored...
ltseung888
Lead-out Energy Flying Saucer Paradigm
Dear All,
We shall have a presentation and brainstorming session on the Lead-out Energy flying saucer paradigm on July 4 (Monday) from 2 – 5 pm at the St. James Settlement and Jockey Club Upcycling Center in Wan Chai.   Address: 6th Floor, No. 85 Stone Nullah Lane, Wanchai, Hong Kong
The agenda will be:
1.    Introduction to Lead-out Energy flying saucer
2.   Demonstration of Lead–out Energy using the Fung Wheel
3.   The many reported UFO sightings
4.   A Nation gets rich by helping others to get rich
5.   Break...
6.   For those interested, do a brainstorming session on how best to proceed
If you are interested in attending, please pm ltseung888.  You are welcome to bring your friends or colleagues.  There will be a small prize if you can pulse rotate the Fung wheel for 10 consecutive revolutions.  The best will be invited to a competition later with a prize not less than HK$10,000.
Meanwhile study the attached presentation (reply 517) and go to the overunity.com forum.  Search using the keywords "ufo propu".  You are encouraged to share the information with others.
http://overunity.com/15077/ufo-propu-engine-closed-loop/msg485700/#msg485700
Regards,
Lawrence Tseung
ltseung888
Mr. T S Lau pulsed a 5V input to 408V Output.  He could set up the circuit...
*** The significant part is that the pulsed output voltage is negative while the output current is positive.  The Product gave Negative Power.  That Negative  Power over the Leading edge of approximately 2ms gave Negative Energy.
***I regard that Negative Energy as proof of Lead-out Energy.
The proper design of the Lead-out energy pulse motor is to get the most Lead-out Energy per pulse...
The Fung Wheel is nowhere near optimum but it showed proof of concept.
*** There are many ways to pulse rotate the Fung Wheel.  The trick is to find the ones that lead-out most negative energy.  Mr. Bill Fung et al will have fun.
ltseung888
Output waveform.
Use the one ohm resistor as load.  Hand spin the wheel.  The AC type waveform is produced.
The rotating magnet induces voltage and Current across the coil.
ltseung888
Review of the Fung Wheel as of Jun 13, 2016
1.   The Fung Wheel used magnet and coil repulsion to pulse rotate an unbalanced wheel mounted vertically.  One coil and one magnet was used.
2.   The leading edge of the pulse showed a large BEMF or Negative Voltage.  The current was still positive.  An example was a 5 Volt DC Input produced a Negative Voltage of -580 Volts.  This produced negative power and hence negative energy for a duration of less than 2ms.
3.   This Negative Energy was regarded as the Lead-out Energy.  One of the criticism of the Lee-Tseung Lead-out Energy Theory was – could you demonstrate and measure Lead-out Energy?
4.   The DSO waveforms were clear indications of the existence of Lead-out Energy.
5.   The Milkovic Two Stage Pendulum leads-out gravitational energy.  The unbalanced wheel is effectively an improved pendulum in leading-out gravitational energy.
6.   The soft iron core of the coil in the Fung Wheel can be thought of as consisting of many tiny magnets arranged at random. The pulsed DC voltage aligns such tiny magnets momentarily.  This leads-out the large magnetic flux or magnetic energy.
7.   Thus the Fung Wheel could be considered as leading out both gravitational and magnetic energy.
So far, Mr. Bill Fung has not come up  with the pulsing mechanism that will produce the large amount of lead-out energy that can be usefully harvested.  However, the 225 Horse Power Pulse Motor with 135 (15x9) magnets invented in USA and funded by Hong Kong achieved that over 10 years ago.
The producing higher angular velocity at the top side of the circle is simple.  The rumor that the Chinese Military Researchers produced the Nanjing UFO within 2 months in 2006 may be a fact.  It should not take long for most Nations to produce their experimental UFOs.
