Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
4.  Heavily Promote the Negative Energy BEMF
One possible intermediate step is to use the BEMF as engine to drive trains or ships.  No need to fly up immediately.
Some people will call this as pulse engine efficiency.  That is fine.  Science moves ahead no matter how people call it.
My approach is to examine the Milkovic 2SO and see that it does lead-out gravitational energy.  This was first proposed to me by the Late Lee Cheung Kin.  We can then focus on the Fung Wheel - leading out both gravitational energy and electromagnetic energy.
The waveforms in the horizontal and vertical positions will teach us a lot...
The high speed trains in China may benefit first with this approach.  People feel safer on the ground.
ltseung888
http://overunity.com/16589/mhs-ideal-coil-and-voltage-question/new/#new
There is intense discussion going on in the above thread.  The question of BEMF and related issues were raised.  Sooner or later, someone will produce the waveforms.  Some of these waveforms will be similar to those in this thread...
The most important part is the high negative voltage and positive current giving negative power over the leading edge of the pulse.  That represents negative energy.
Can that negative energy be interpreted as bringing in electromagnetic energy from the environment?
When we place the Fung wheel horizontally, we get less negative voltage.  Can we interpret that as less gravitational energy was brought in?
If we can bring in gravitational energy, should we re-examine the Milkovic 2SO.
China and USA Military have mastered that long ago.  Man made UFOs are flying.
China is still using conventional rocket technology:
https://www.youtube.com/watch?v=uXJOQtECsGw
It will not be long when the new UFO technology is used...
ltseung888
Someone questioned the validity of the Fung Wheel.  At overunityresearch.com, someone proposed to ban my posting.
The Fung wheel is the beginning of the design of the ninth version of the Flying Saucer.
The diagram is reproduced here.
The details are in the overunity.com "ufo propu" thread starting in reply 1.
What is so special about the Fung Wheel is that it is a combination of the following concepts.
1.  Leading out of gravitational energy.
2.  Leading out of electromagnetic energy.
3.  Unbalanced Wheel replacing the pendulum.
4.  Net thrust produced via the difference in Centrifugal Forces.
5.  The capturing of the Negative Voltage waveform on the leading edge of the pulse.
I shall explain each in more detail..
The Milkovic 2SO showed that the seesaw action is created by the centrifugal force of the pendulum.  When the pendulum is at the lowest position, its velocity is highest.  That gives rise to the highest centrifugal force.  The Rhead video 5 clearly showed that the weight on the LHS was lifted at the moment of the lowest position of the pendulum.  The lifting of the weight did not significantly lower the amplitude of the pendulum.  Where does the energy come from?  My interpretation is that it comes from gravity.  The Fung Wheel gave us confirmation.
When we measure the waveforms of the Fung Wheel in the Vertical and in the Horizontal positions, we found that the Vertical position gave about one-third more.  In the vertical position, the Fung Wheel essentially replaced the pendulum action with that of the rotation of an unbalanced wheel.
We know that ferrite material can be thought of as consisting of many tiny magnets arranged at random.  When DC Current is passed to magnetize it, these tiny magnets align to become a large magnet.  The question is that whether the electrical energy used to magnetize the ferrite material E1 can be smaller than the resulting magnetic energy E2.  The first experiment we did was straight line coil and magnet repulsion.  At Hong Kong University, one experiment was tried.  One 130 turn coil was used to repel one circular magnet.  The electrical Energy Input was measured on a DSO.  The output Energy was taken to be the potential energy of the resultant jump (mgh).  The result was a disappointing COP of 0.06 or 6%. The researcher gave up!
We took the equipment back from Hong Kong University.  The number of turns was increased to 600.  The number of magnets were increase to 4.  The COP increased to 0.3 or 30%.  The Input Pulse was carefully examined.  The duration of the Pulse is actually dependent on how long the researcher pressed the button.  It could vary from 100ms to many seconds (if the researcher did not release the button).  The COP=0.3 was obtained with the Pulse Time of around 200ms.
The question of whether we could reduce the Pulse Time was raised.  If we could have a short pulse of 50ms, we might get COP greater than 1.  In playing with rapid pulses, we observed a sudden high negative voltage.  Initially, some remarked that it was just the normal BEMF as the duration was only 1-2ms.  But the current was positive while the voltage was negative.  That gave rise to negative power.  During those 1-2ms, we have negative energy.
I immediately took that as representing lead-out energy.  Mr. Bill Fung decided to build the circular Fung Wheel.  To our delight, we could observe very high negative voltage.  A 5 V DC Input can give a -580 V waveform.
If the negative energy is indeed the lead-out energy, the 225 HP Pulse Motor developed in USA but funded by Hong Kong may be a reality.  (That device is considered top military secret in both USA and China after Lee Cheung Kin and I explained its operation at Tsinghua University in 2006.)
If the Milkovic 2SO can lead-out gravitational energy, a magnetic pendulum must be able to lead-out or bring-in magnetic or electromagnetic energy.  All we need is to replace the pendulum bob with a magnetic bob and place permanent magnets in appropriate places.  Gravitational forces are everywhere including outer space.  It will still be there if the object is cooled down to absolute zero degrees.  Some people call this zero point energy.
The Tsinghua University Energy Multiplier used three unbalanced cylinders.  A cylinder can be considered as many wheels put together side-by-side.  Thus the fact that it can have COP of 30 is no surprise.
Some Christians told me that the principle was shown in the Bible.  King David killed the Giant Goliath with the sling.  We realized that this might be the reason for the top military secret.  A man-made UFO is possible.  Two months after our Tsinghua presentation, an UFO appeared over Nanjing...
We now have the Fung Wheel in Hong Kong clearly showing the large  negative voltage at the Leading Edge of the good pulses.  Some pulses even have the large negative voltage at both trailing and leading edges.  Most pulse motor researcher did not realize the importance of this negative voltage.  (A bad pulse can indeed rotate the wheel back!)  Manually built pulse wheels could easily have mixture of good pulses and bad pulses.  We now understand why the Tong Wheel was so difficult to tune...
ltseung888
Circuit diagram for the Fung Wheel
Be sure to connect to the DSO correctly.
ltseung888
Repeat of the straight line repulsion case.
The important thing to note is that the Negative Voltage is clearly shown.
Is it lead-out energy?  Can the electrical input energy align the tiny magnets to produce the lead-out energy?
