Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
One full set of experimental equipment is now at Hong Kong University.  Prof. Leung will put the experiment on firm scientific footing.  That includes:
1. Better Oscilloscopes
2. Better machine winding and thicker wires
3. Electronic control rather than hand pushing
4. Much more data
5. The COP > 1 cases will be proven beyond any shadow of doubt.
6. Eliminate as much as possible all known sources of error.
Let the Students catch the Big Fish.  Let them shine...
At least one academic institution is taking action.  Will USA or Chinese Government disclose the top secret?
*** The material cost including the DC Power Supply and the Atten DSO was less than HK$5,000.  Many academic institutions already have DC Power Supplies and better DSOs.  The additional material cost of tubes, magnets, coils, resistors etc. to do the experiment would be less than HK$500.  This experiment can verify or confirm COP greater than 1.  It can be a very motivating experiment for the Students.  It may solve the energy and transportation problems of the World...
Should a scientific institution sit and wait for HKU to publish the results?  Or should it do the experiment itself now?
Is it possible for USA or Chinese Governments to suppress such scientific research?
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg50206#new
MarkE
Sophisticated equipment used improperly yields bogus results.  It's pretty simple:  Fixture carefully and properly, or you might as well not bother to take measurements.  Things like clip leads strewn all around and cement wirewound resistors for current sense easily get fouled by switching edges.
ltseung888
Will repulsion of two iron-core coils be the best configuration to detect overunity?
One magnet and one iron-core coil will experience magnetic attraction even with no Current.
Two iron-core coils will have no magnetic attraction with no Current.
May use same circuit to pass same current through both coils...
SoManyWires
Quote from: ltseung888 on August 19, 2015, 05:37:39 PM
wondering something,
could a spring or springs made with peizo sensors help reduce the amount of energy needed to create lift inside the chamber?
would the spring placed above make the moving object lift easier while holding back the tension of gravity?
the lower spring helping by using the objects weight to help lift itself during the cycle.
the peizo sensors are just to help feed some of the power back into storage.
ltseung888
The magnetic strength of the solenoid is dependent on the Current and the number of Turns.  These two parameters can be increased so that the magnetic repulsion will generate high Output Potential Energy mgh.   The Input Electrical Energy does not need to increase very much.  This means the hunt for overunity should focus on thick wire and large number of turns.
I am sure that the Hong Kong University Students will catch the Big Fish - using thick wire, low resistance, high current and huge number of turns...  COP > 1 is achievable.  I look forward to the results.  Some of the Input Electrical Energy is used to align the "tiny magnets" of the iron-core to produce a large magnet.  This is a clear case of leading-out magnetic energy...
The Fish can be so Big (COP so high) that the experimental inaccuracies are not a concern...  Who are the names that shine?  Will other academic institutions wait and watch HKU or will some charge ahead and catch the Big Fish first?
Will China or USA Government disclose the top secret?  Their UFOs are flying...
Lawrence
