The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Cadman
So here we are. Another thread derailed before any meaningful discussions or tests are done with the original design.
Instead all the experts have weighed in and denounced it as a hoax and now we see "replications" that have no resemblance to the actual device proposed.
Tell us, all you 'experts' and replicators:
What is the pole arc of the exciters?
What is the pole pitch of the iron rotors?
What is the ratio of pole arc to pole pitch? Is it the same for both the exciters and rotors?
How many stator coil slots are there? How many are used?
What winding pattern is used in the stator for either 1 phase or 3 phase?
Where is slot #1 of the stator winding in relation to a stationary exciter pole? Is that important?
Does the winding start above a N or S pole? Does it start as clockwise or counter clockwise? Does it matter?
How many degrees does the iron rotate before the polarity flips?
Does the rotating iron flip polarity while it is influencing a coil loop? If it does then how many coil sides of how many loops are affected? One, or more than one? How would that affect the output?
None of you know the answers because you haven't designed or tested anything resembling the concept of the original device.
Yet we are being told by the experts here that it can't work, it's obviously a scam, and others are claiming to possess confidential information and know the secret of why it works.
Bah!
Now go on, ignore what I wrote. Build something that doesn't resemble the original and prove that it doesn't work.
Dave45
An idea to rotate the iron separators on a fixed shaft using an open frame design.
The pullys then could be rotated using a belt
lumen
Quote from: Cadman on November 22, 2014, 09:59:05 AM
Cadman,
Yes, that is exactly the problem. No one was ever given the plans to the ORIGINAL design.
The plans given are not what was demonstrated in the original video so building the original plans is simply an unknown design.
I'm sure there are some working on this to try and re-discover the demonstrated device.
T-1000
Quote from: lumen on November 22, 2014, 12:43:04 PM
Yes, there are silent builders trying to apply W. Garry magnetic effect in generator as this can be easily guessed from CAD drawings in another thread and that looks most logical one...
lumen
Yes, even the Ecklin generator is simple and easy to build.
I wonder how many have built this and are now enjoying free energy?
