The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Dog-One
Quote from: Cadman on November 22, 2014, 10:47:29 PM
If you or anyone here has one of these single phase ST generators and would chart out the coil layout for us I'm sure a lot of people here would find it useful. The ST winding configuration could even be crucial to the success of this gen.
Just a thought...
For those that go with a factory single phase 4-pole stator, try to make your inner core adjustable with some sort of angle dial indicator.  I don't think anyone knows for sure what the proper alignment is between the fixed inner core and the fixed stator winding.  It's quite possible this angular adjustment will allow optimization at different RPM and load conditions.  I'd be willing to bet there are several sweet spots having tight tolerances of just a few degrees.
Jimboot
At 40v now with a small pu coil. I will be adding another three. Hopefully the effect is linear. Amps are pretty low so I'm just focusing on max the voltage. Uploading new vid now. I find when I put the coil between two poles it gets its greatest voltage. Also the bigger mags get greater voltage.
tinman
Quote from: lumen on November 22, 2014, 03:04:24 PM
Yes, even the Ecklin generator is simple and easy to build.
I wonder how many have built this and are now enjoying free energy?
No one
Jimboot
I was re-reading the wesley gary paper http://www.rexresearch.com/gary/gary1.htm posted by T-1000 and decided to try a different coil position. Just cracked 100v with a single coil. I want 1kv now :) I think I'll need at least 10watts..
Jimboot
Here is the earlier video. https://www.youtube.com/watch?v=ya3JmneZIVQ apologies for the camera work. I think I have that sorted now.
