The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
DreamThinkBuild
Hi Grumage,
Nice test build.
Attached is an idea for a linear version.
The iron plate would have to be placed a little over the neutral line to create a opposite polarity.
Initially the drive magnet will pull upwards attracted to the fixed magnet. As the iron plate comes down it reverses polarity
making the drive magnet drop back down hitting the lever repeating the cycle (if it doesn't stick somewhere) :) .
Enjoykin
T-1000 stop flooding on this thread,
This is Syairchairun's theme about his OU generator -  not topic about magnetic levers and tricks with B-field. !!
His OU generator is in fact S-machine (Scalar generator) using Dr.Nikolaev and Dr.Marinov formulation.
As i have found your parallel posts on 3 independent forums.  This is not normal reaction for human but quite @normal@ for governement trolls.
Your trolling is very skilful and you are many years in this @governement issue@.
You are continuously running water on your watermill - from topic to topic.
That's all people.
Enjoykin
Quote from: l0stf0x on November 22, 2014, 03:51:20 AM
Hi Enjoykin, Do you have any more info about that? What you think he mean? special structure of the material? premagnetized? ??
http://www.pennstatehershey.org/c/document_library/get_file?folderId=1176176&name=DLFE-15206.pdf
Hello l0stf0x  :D
No - I have not. I am waiting Syairchairun to come again here and present Magnetic Poles configuration. So i know he is using some magnetic configuration inside soft iron rotor. All other is trivial. Magnetic configuration in his setup is KEY for OVERUNITY in S-MACHINE. And am sure 99% that he is using one of SIBERIAN COLIA CONFIGURATION.
I was reading spanish patent of Hogan-Jakovlevic from 1950 and found exactly configuration like in Dr.Marinov S-machine. Only one stuff here is ENIGMA. Some kind of plate (grid) between TWO SIBERIAN COLIA MAGNETS IN ANTIPHASE. If you put simple copper silever or gold plate (grid) between you will get nothing - already was tested on our Russian forum. I am searching for similar Tesla setup to associate with SECRET GRID FORM. For now only Tesla Basket Coil (Bifilar type) come to my mind. What about if the whole trick is in "bread and butter bifilar sandwich" ?. I know Ismael Aviso using Tesla Pancake Bifilar sandwich of many coils as RADIANT COLLECTOR in his OU generator.
Now i show you how Scalar Magnetic Field exactly look in visible spectrum. Picture below is early borned young star in Perun constellation -  (known as Eagle constalation 1 of 16 constalations visible from our planet.) You can see Star Toroid which is perfect source of Scalar Magnetic Filed. Maximum of Scalar field is at center and going on two opposite sides of toroid. Vector magnetic field B was trapped inside toroid and can't escape nowhere. This is the case with any perfect toroid. Look on the colour fountains at both sides of toroid. They track configuration of Star Scalar Magnnetic field. But real configuartion is very complex because we need to see complete spectra from 0Hz to 1034Hz for real configuration and dynamics of Star Scalar Field. Picture is from Japanese telescope month ago.
Here on our site http://www.tesladevice.ru/forum you will find many interesting videos and experiments about Scalar Magnetic Field of Dr. Genady V.Nikolaev
https://clck.ru/9NAez
Two non valid experiments - Spanish patent from 1950 225315
http://www.youtube.com/watch?v=0WmS1I7b6ws
http://www.youtube.com/watch?v=1mANxFntqCA
In my oppinion succession of experiments here need to be done from simple to complex configurations.
For starting experiments should be used single bare wire conneced with both ends to oscilloscope. There should be used diferentials probes. Than experiments with two wires with two differential probes. All configuration angles shoudl be tested and interesting envelopes recorded for analyse. Than experiment with 3 bare wires and 3 differential probes. After all of this shoud be tested some of  braiding grid configuration. For example zigzag configuration of two isolated conductors with appropriate ange. Example Handershot Basket weave coils, Tesla bifilar pancake coils, Hooper pancake coils. If there is positive result than shoud be tested some of basic Platon Solids geometric bodies and shapes. One of variant can be rotating grid made from copper, soft iron or maybe gold - like in Syairchairun setup.
One thing i know - IT MUST BE PERFECTLY SIMPLE - because Mother nature never had made complex stuffs or in my free interpretation looking from her point of view -  Human entities are also SIMPLE STUFFS (configurations)  same like MOTHER UNIVERSE !!  :D
Reg,
enjoykin
l0stf0x
Thank you very much Enjoykin, your explanation is more than perfect..!! Just great info for learn think and practice .. !!  :D
T-1000
Quote from: Enjoykin on November 24, 2014, 11:03:27 AM
That's all people.
From now I will be ignoring your posts. Getting called as troll second time is not fun anymore and the Marinov setup has nothing related to Syairchairun's setup. If you are blind not seeing that in http://www.overunity.com/15088/new-generator-no-effect-lenzlaw-give-more-detail-in-pcture/dlattach/attach/144160/image// (posted by syairchairun in http://www.overunity.com/15088/new-generator-no-effect-lenzlaw-give-more-detail-in-pcture/msg423162/#msg423162 ) that is your personal problem...
P.S> When something really working appear in forums then always there will be people to derail original information to something else so no one can repeat original setup.. Think twice before doing that.
Also Grum did prove point what is happening when there is moving iron bar between two magnets (the coil is alternating magnet) in his https://www.youtube.com/watch?v=ACykTfXspfM so now back to original syairchairun build and making replication... My posts was even one step further for making it magnetically balanced but it might be too early in time at this point. Will see in few months.
