The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Jimboot
Quote from: Just..Sayin.. on December 07, 2014, 07:01:26 AM
Just wondering if you confirmed your results yet with current measurements on the input, rather than relying on the sound of the motor?
No sorry, only no change in volts. My rotors have been too unstable, my best guess is that it is no where near unity yet let alone over, but I do believe I can power a bulb without no extra power required, however that is no ou. Does give me more reason to experiment tho.
gyulasun
Quote from: gotoluc on December 06, 2014, 06:32:38 PM
Hi Gyula,
you answered my question well, thank you.
Below are some new Scope Shots. First open coil, then 100, 50, 25 and 12.5 Ohms loads with Power calculation included included
Luc
Okay, and thanks for showing the new tests.  Unfortunately, the supposedly high DC resistance of the ex shaded pole motor coil works against the generated juice and this may also shadow part of the Lenz effect by not letting high enough current to flow through the loads.
Maybe your hand is able to sense drag (if any) in the spaced away magnets setup too so that you coud compare results to the closer spaced magnets case.
Gyula
Just..Sayin..
Quote from: Jimboot on December 07, 2014, 07:16:40 AM
This is what we are interested in knowing.... it is a given that you will not achieve o/u with that prototype, and that does not matter... a current measurement would be nice to see, to know if there is anything going on.
gotoluc
Quote from: gyulasun on December 07, 2014, 08:09:05 AM
Gyula
Unfortunately my hands cannot sense the difference between loaded and open coil. A motor powered rotary version would need to be built to detect such a change.
Before putting more time and resources in this I would need to see some kind of encouraging evidence that this design actually makes a difference.
Best thing I have seen so far is Farmhand's post on this topic but at the OUR forum which has nothing to do with this effect and everything to do with my friend Thane Heins ReGen-X effect.
Luc
Jimboot
Quote from: Just..Sayin.. on December 07, 2014, 11:16:13 AM
Yep no doubt. [size=78%]http://youtu.be/bHR-dlGV4oM[/size] is where I am currently at. I'm trying to get a balance between output and stability
