The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Cap-Z-ro
Being smart enough to realize you don't know is a big boy step.
Only one of us has taken that step.
This particular troll has however, learned to stand clear when I express a definitive opinion on something in one my fields of endeavor...because unlike him I know of what I speak and do not bullsh!t people.
I do know as much about magnetism as this punter though...which is not a lot, by comparison.
Regards...
How dare you insinuate that I lie and that I don't know what I am talking about.  You are a morally bankrupt individual and you are ruining this thread.
MarkE
Quote from: MileHigh on December 09, 2014, 11:21:47 PM
Cap has offered one piece of advice that I suggest all consider very seriously:  Don't feed trolls.
Cap-Z-ro
Well...lets break this down for the forum 'knowitall'.
When making statements of fact as it relates to magnetism, that is in effect 'bullsh!tting'.
And its virtually impossible to run off at the mouth like he does without spreading some.
No one has said so much and done so little.
Regards...
gotoluc
Quote from: MileHigh on December 09, 2014, 08:27:19 PM
What would be easy, would be to confirm that there is no delayed Lenz effect.  If you have a scope you can look at the current flowing through the pick up coil and the position of the rotor magnet as it passes the pick-up coil.  You will quickly see that there is no "delayed Lenz effect."
What if we have a coil which accelerates under load (AUL) and wind a high current coil over it.
Now we have two coils on the same core. The only difference is, one AUL and the other does not.
We connect a 1 Ohm resistor to each coil and add scope probe across each.
First we put the AUL coil under load and wait till the RPM is stable, then we also load the high current coil.
What do you think we should see on the scope? will each resistor sinewave happen at the same time or could we see a phase shift between each load resistor?
Luc
