The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
0 Members and 70 Guests are viewing this topic.
I'm assuming that he read my posting, realized his first build was nonsensical, and then quickly changed it and did a new clip without saying anything.  So are you going to shoot me?  If you make a mistake and somebody corrects and helps you in the process just stating that shows some character.  You don't need to play the knight in shining armor there Chet.
ramset
MH
One mans Nonsense is another mans experiment.
Luc is a very humble person and there are those reading here who may be unaware of his Life experience and  place weight in your "Assumptions, statements and innuendos.
Thanks Grandma
Jimboot
Quote from: Mister Caribbean Roots on January 06, 2015, 07:46:08 PM
Hi Luc,
Nice going with them experimentings... ;D
I would say to remove the upper part and put in it's place a iron disk with holes... ;)
Anything from 3mm or more in thickness is enough to get the magnetic flux to switch... :)
Drill as many holes as the particular diameter can take...this way you have more switching going on per rpm and it should/might help to reduce the cogging also... ;)
You must leave enough spaces between the holes to get the switching going...i would say...holes and spaces in between...same diameter/lenght... ;)
If it's difficult to get a perfect iron disk a square one will do just fine aswell...it has to be as square as you can get it so not to have to much vibrations... :)
The same can be done with the bottom part to when you are satisfy with the upper part... 8)
It would look like a octopus...lots of legs with coils on them...as many you can get in the particular diameter of your setup... 8)
By having upper and bottom like this you will have a lot more switching going on in lots of coils... 8)
Maybe this configuration will help with the cogging or maybe not...lol... ::)
Cheers
In my exp the cogging is eased with more poles. 5watt out  :o :o Sweet! Need to get some big arse wire :)
Pirate88179
Quote from: ramset on January 06, 2015, 06:10:27 PM
MH
you want to be loved and appreciated go buy a Puppy...
Chet
Chet, no need to EVER buy a puppy, or kitten for that matter.  Just make a trip to your local animal shelter and adopt one.  My new (well, new as of 3 years ago) lab assistant is a rescue kitty I saved from being killed, like his mother, brothers and sisters were.
I know this was just a small part of your post, but I could not help but jump in a recommend that folks never buy a pet when there are so many at shelters needing a good home.
Thank you,
